Cisco 2960 boot problem
m_irfan96_swb1
Visitor
Cisco 2960 doesn't boot properly and only system led is Green in one environment and works fine in other environment what may be the possible causes.
Input power is 230 VAC
Reza Sharifi
Are you using the same power cord in both environment? if not it could be bad cord. Also, do you have sufficant power in the environment that it does not boot properly?
luis_cordova
Hi @m_irfan96_swb1 ,
Queries:
Do you turn on the device without any device connected?
If you turn it on with connected devices, will they be creating some overconsumption of energy?
Leo Laohoo
Console into the switch and reboot the switch.
Post the entire boot-up process.  We want to see what is going on with the appliance.
Martin L
try switch mode , aka password recovery. press and hold mode button , turn on device, let go mode button after 15 seconds
