Cisco 2960-s - fix IP for web gui
Drug_Store
I have a Cisco 2960-s, and all I want to be configured is a simple web gui access.
I reset it, only added the name and password by cli, but I dont see it in my network.
I don´t need any configuration (all connected devices will receive DHCP from another device), but I need to access the 2960-s by web GUI once in while (since sometime I´m not near it to access by cli).
I´ve been struggling to config it. I´m sure, this is simple, but not for me
All I need is to be default configuration (vlan1, etc), and the switch to have fixed IP for me to access by web GUI.
Can someone guide me?
Thank you
Add this Lines  and test it
username cisco privilege 15 password cisco123   <---- whatever username and password you looking to use
aaa new-model
aaa authentication login default local
aaa authorization exec default local
ip http server
ip http authentication local
EDIT : just observer your vlan interface down,
config t
interface vlan 1
no shutdown
end
connect one of the ports and check from the console is the vlan up, configure the PC with 192.168.1.X, and ping Switch IP, if you ping then try GUI.
BB
11 Replies 11
I think you need to config HTTP/HTTPS in SW to access via GUI
Yes, perhaps... but how?
Procedure 1 - Configure The HTTP Server On The Switch | Global Switch Configuration | Guides
START first with HTTP then config HTTPS (HTTPS need domain and crypto key, so if you success with HTTP no need this command).
Note:- enable HTTP in SW make SW listen to HTTP port and you can see some DDoS attack.
balaji.bandi
You need to have correct TAR image to get full GUI for your device.
post below output from device :
show version
dir
Other Option you can configure from CLI using SSH if you are able to reach GUI means you can able to SSH to the device.
below DHCP should work :
service dhcp
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp pool LANPOOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
interface GigabitEthernetx/x
ip address 192.168.50.1 255.255.255.0
no shtudown
or
interface  vlan 1
no shutdown
BB
Here´s the version :
cisco WS-C2960S-24PS-L (PowerPC) processor (revision M0) with 131072K bytes of memory.
Processor board ID FOC1845Y3SP
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : E0:89:9D:4B:31:80
Motherboard assembly number : 73-11908-10
Power supply part number : 341-0393-02
Motherboard serial number : FOC18450C4L
Power supply serial number : DCA1841U0K7
Model revision number : M0
Motherboard revision number : A0
Model number : WS-C2960S-24PS-L
Daughterboard assembly number : 73-11933-04
Daughterboard serial number : FOC18444UYD
System serial number : FOC1845Y3SP
Top Assembly Part Number : 800-30945-04
Top Assembly Revision Number : F0
Version ID : V04
CLEI Code Number : COMGE00ARD
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960S-24PS-L 15.2(2)E9 C2960S-UNIVERSALK9-M
Configuration register is 0xF
Yes, perhaps  - not sure is this means you have a TAR file.
you have not posted the below output :
#dir
#show run
BB
Cisco2960-s#dir
Directory of flash:/
2 -rwx 34 Jan 2 2006 00:02:36 +00:00 pnp-tech-time
3 -rwx 10867 Jan 2 2006 00:02:38 +00:00 pnp-tech-discovery-summary
4 -rwx 3782 Jan 18 2022 00:30:40 +00:00 startup-config.bak
5 -rwx 10264 Jan 2 2006 00:00:52 +00:00 multiple-fs
6 drwx 512 Jan 9 2022 15:39:04 +00:00 c2960s-universalk9-mz.152-2.E9
672 -rwx 1920 Jan 2 2006 00:00:52 +00:00 private-config.text
673 -rwx 99 Jan 3 2006 22:32:47 +00:00 express_setup.debug
674 -rwx 2019 Jan 2 2006 00:00:52 +00:00 config.text
57931776 bytes total (35276800 bytes free)
Cisco2960-s#sh run
Building configuration...
Current configuration : 3313 bytes
! Last configuration change at 00:00:46 UTC Mon Jan 2 2006
version 15.2
no service pad
hostname Cisco2960-s
boot-start-marker
boot-end-marker
enable secret 5 *****.
enable password ****
no aaa new-model
switch 1 provision ws-c2960s-24ps-l
crypto pki trustpoint TP-self-signed-*****
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-*****
revocation-check none
rsakeypair TP-self-signed-****
crypto pki certificate chain TP-self-signed-*****
certificate self-signed 01
quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
ip address 192.168.1.45 255.255.255.0
shutdown
ip http server
ip http secure-server
line con 0
line vty 0 4
password *****
login
line vty 5 15
password *****
login
end
Vlan1 shutdown? Maybe I´m doing something wrong...
Drug_Store
flash:/c2960s-universalk9-mz.152-2.E9/c2960s-universalk9-mz.152-2.E9.bin
if I reset it, I can see it in my network as 192.168.1.40, and I can actually open a browser and asks for user/pass, which nothing works since I didn´t define it yet. After start the system configuration by CLI and trying to define it to 192.168.1.45 with my password, never get to see him my network afterwards.
aaa new-model
ip http server
config t
interface vlan 1
no shutdown
end
BB
Still no success
Can you tell me step by step, how to config it from the reset state?
Thank you very much
Drug_Store
Sorry for late reply. Thank you, got it working.
