Cisco 2960-S Model:WS-C2960S-48LPS-L - After Upgrade IOS to 15.2(2)E9 - Boot System flash: Does not appear
Hi Cisco Peeps,
I have a Cisco 2960-S Model:WS-C2960S-48LPS-L, I upgraded to IOS 15.2(2)E9 then after the upgrade,
"boot system flash:" is not appearing and I want to roll back to 12.2 IOS (c2960s-universalk9-mz.122-55.SE5).
boot system c2960s-universalk9-mz.122-55.SE5  - NOT Working.
Switch#sh flash
Directory of flash:/
3 -rwx 676 Mar 1 1993 00:02:12 +00:00 vlan.dat
587 -rwx 4120 Jan 2 2006 00:00:53 +00:00 multiple-fs
4 -rwx 28009 Jan 2 2006 00:02:52 +00:00 config.text
5 -rwx 16800768 Mar 1 1993 00:38:00 +00:00 c2960s-universalk9-mz.152-2.E9.bin
6 -rwx 3833 Jan 2 2006 00:02:53 +00:00 private-config.text
7 drwx 512 Mar 1 1993 00:14:43 +00:00 c2960s-universalk9-mz.122-55.SE5
57931776 bytes total (25701376 bytes free)
Switch#show boot
BOOT path-list : c2960s-universalk9-mz.122-55.SE5
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : yes
Manual Boot : no
Allow Dev Key : yes
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
NVRAM/Config file
buffer size: 524288
Timeout for Config
Download: 0 seconds
Config Download
via DHCP: disabled (next boot: disabled)
Can you guys please help me out to solve this issue?
Much appreciated and thank you in advance.
Erwin
11 Replies 11
Reza Sharifi
What is the output of "sh ver"?
try:
no boot system flash: c2960s-universalk9-mz.152-2.E9.bin
boot system flash: c2960s-universalk9-mz.122-55.SE5
Hi Reza,
"boot system flash:" command does not recognize. see below:
mhi-ps-farm-01(config)#boot system ?
WORD pathlist of boot file(s) ... file1;file2;...
switch Set system image for switches in the stack
"sh ver" output below:
mhi-ps-farm-01#sh ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.2(2)E9, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sat 08-Sep-18 14:56 by prod_rel_team
ROM: Bootstrap program is C2960S board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWARE (fc1)
mhi-ps-farm-01 uptime is 51 minutes
System image file is "flash:/c2960s-universalk9-mz.152-2.E9.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48LPS-L (PowerPC) processor (revision E0) with 131072K bytes of memory.
Processor board ID FOC1638W43G
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
80 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 54:78:1A:8A:C1:80
Motherboard assembly number : 73-11907-08
Power supply part number : 341-0393-02
Motherboard serial number : FOC16382Z53
Power supply serial number : LIT16320YZ9
Model revision number : E0
Motherboard revision number : A0
Model number : WS-C2960S-48LPS-L
Daughterboard assembly number : 73-11933-04
Daughterboard serial number : FOC16374LLS
System serial number : FOC1638W43G
Top Assembly Part Number : 800-30937-03
Top Assembly Revision Number : A0
Version ID : V03
CLEI Code Number : COMGZ00ARC
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960S-48LPS-L 15.2(2)E9 C2960S-UNIVERSALK9-M
Configuration register is 0xF
Hi Reda,
See below after I reload the switch. There is an Error loading "flash:c2960s-universalk9-mz.122-55.SE5"
Loading "flash:c2960s-universalk9-mz.122-55.SE5"...flash:c2960s-universalk9-mz.122-55.SE5: is a directory
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2960s-universalk9-mz.152-2.E9.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c2960s-universalk9-mz.152-2.E9.bin" uncompressed and installed, entry point: 0x3000
executing...
this is directory c2960s-universalk9-mz.122-55.SE5
check the -  dir flash:/c2960s-universalk9-mz.122-55.SE5
BB
Hi Balaji,
Please see result below. May I know what command to I need to make this work?
Switch#dir flash:/c2960s-universalk9-mz.122-55.SE5
Directory of flash:/c2960s-universalk9-mz.122-55.SE5/
8 drwx 6144 Mar 1 1993 00:09:02 +00:00 html
585 -rwx 10956042 Mar 1 1993 00:10:29 +00:00 c2960s-universalk9-mz.122-55.SE5.bin
586 -rwx 484 Mar 1 1993 00:13:48 +00:00 info
try below
no boot system flash:c2960s-universalk9-mz.122-55.SE5
boot system flash:c2960s-universalk9-mz.122-55.SE5/c2960s-universalk9-mz.122-55.SE5.bin
if the switch gone to switch prompt , then try below :
switch: set BOOT flash:c2960s-universalk9-mz.122-55.SE5/c2960s-universalk9-mz.122-55.SE5.bin
switch: boot
another question ? have you tried to upgrade ? or degrade ?
BB
Hi Balaji,
Thank you for the Information. I got it worked by delete the c2960s-universalk9-mz.152-2.E9.bin
delete flash:2960s-universalk9-mz.152-2.E9.bin
wr
reload
after reload it recognize the c2960s-universalk9-mz.122-55.SE5.bin old IOS version 12.2
Thank you for your help.
is this mean all working ? or issue?
BB
It's all working. Thank you for you help.
if all good mark as a solution so it will be useful for other users.
BB
Try moving the file from directory called "c2960s-universalk9-mz.122-55.SE5" to the root of the flash before setting boot variable.
copy flash:c2960s-universalk9-mz.122-55.SE5/ cc2960s-universalk9-mz.122-55.SE5 flash
