12-11-2019 01:16 PM
Hi there,
I'm trying to figure out which physical ports on nexus 2000 connect to 5000?
I did show command on 5000: show interface fex-fabric. but it only showed the ports on nexus 5000. I'm looking for the ports on 2000. Does anyone know the command? Thank you!!
Solved! Go to Solution.
12-11-2019 01:43 PM
Fex Uplink: 1 - there is number on the FEX - depends on module you can see the numbers there
this means your eth 2/3 connected to uplink 1
12-11-2019 01:18 PM
on the nexus 5K issue below command :
show fex XXX details - it will show the links connected to FEX device.
12-11-2019 01:21 PM
Thank you. this is the result
Fabric interface state:
Po101 - Interface Up. State: Active
Eth2/3 - Interface Up. State: Active
Eth2/4 - Interface Up. State: Active
Po101 is just a port channel, but it still doesn't tell me what physical port on nexus 2000
12-11-2019 01:25 PM
First, is the fex online?
do this command to see the fex first
sh fex
and than show fex xx detail
12-11-2019 01:26 PM
Yes it's online
12-11-2019 01:30 PM
apologies this should show what uplink it connected
show fex xxx transceiver
12-11-2019 01:35 PM
At below, its' the result. but e2/3 is the interface on 5000.Maybe im not clear what i'm looking for. In order to make 2000 runs, there must be a physical cable connects between 5000 and 2000. e2/3 is on 5000, what's the interface on 2000?
Fabric Port: Ethernet2/3
Fex Uplink: 1
sfp is present
name is CISCO-FINISAR
type is xxxxxxxxxxxx
part number is xxxxxxxxxxx
revision is A
serial number is xxxxxxx
nominal bitrate is 10300 MBits/sec
cisco id is --
cisco extended id number is 16
12-11-2019 01:43 PM
