Cisco 2960 switch has amber light on solid
barryrosenhouse
Cisco 2960 switch has amber light on solid on my switch when customer plugs in cable to their switch, i config's as a trunk port and an access port. took off  spanning-tree portfast and
spanning-tree bpduguard enable to test. did a shut/no shut and still Down /Down amber light still on
SW-xxxxxxx1#sh int f0/14
FastEthernet0/14 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is xxxxxxxxxxxxxxx
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
11 Replies 11
barryrosenhouse
Cable was replaced, what do you mean the POE, is there a setting power-over-ethernet that needs to be changed?
barryrosenhouse
Will do, this is switch to switch BTW
this is cisco SW the other SW is different vendor ?
marce1000
 - Check the logs too , when that happens
 M.
barryrosenhouse
yes the other switch is a cisco
barryrosenhouse
Ok will check logs too
both are SW,
Increase the priority of SW and try connect,
I think other SW config Root guard and err-disable the port and you notice this in this SW.
balaji.bandi
is this for port or switch LED :
some LED indications :
https://community.cisco.com/t5/small-business-switches/cisco-2960-switch-led-indication-problem-urgent/td-p/2987185
BB
Leo Laohoo
Post the complete output to the command "sh post".
