Cisco 2960G - Web interface not available in HTTPS, only in HTTP, why ?
Elrick Landon
Level 4
Level 4
Hi to all,
I just updated my Switch 2960 to the latest release, 12.2(55)SE11 (c2960-lanbasek9-tar.122-55.SE11.tar).
All is working fine even if i try to access to Cisco web interface in HTTPS.
If i active http web interface => HTTP OK
If i active https => HTTPS KO, telnet on port 443 is open, but Nothing is answering behind...
I dunno why, i post here my configuration :
Using 2192 out of 65536 bytes
! Last configuration change at 18:03:56 cest Sun May 7 2017
! NVRAM config last updated at 18:04:06 cest Sun May 7 2017
version 12.2
no service pad
service password-encryption
hostname C2960G-1
boot-start-marker
boot-end-marker
enable secret 5 $1$0UPl$SuJI1pntqnY8deafJonJe/
enable password 7 0871141C0C4B55
username Cisco privilege 15 secret 5 $1$kG7o$22gaI1msYYIOqvKn0oKKV1
no aaa new-model
clock timezone cet 1
clock summer-time cest recurring last Sun Mar 3:00 last Sun Oct 3:00
system mtu routing 1500
ip domain-name mondomaine.local
crypto pki trustpoint TP-self-signed-3541658880
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3541658880
 revocation-check none
 rsakeypair TP-self-signed-3541658880
crypto pki certificate chain TP-self-signed-3541658880
 certificate self-signed 01 nvram:IOS-Self-Sig#3030.cer
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface Vlan1
 ip address 192.168.1.250 255.255.255.0
ip default-gateway 192.168.1.1
no ip http server
ip http authentication local
ip http secure-server
line con 0
 exec-timeout 0 0
line vty 0 4
 password 7 12495D4517595C
 login
line vty 5 15
 password 7 055B5E5D241E1E
 login
ntp clock-period 36028801
ntp server 62.4.12.66
ntp server 94.23.217.75
end
8 Replies 8
Georg Pauwen
try and configure an aaa model as below:
aaa new-model
aaa authentication login default local
username cisco secret mysecret
I add it, nothing new, the webinterface is still not reachable
So if i want to remove it, i add "no aaa new-model", is it correct ?
Elrick,
the problem might be with Internet Explorer and/or recently installed Windows Security Updates.
If possible, try Firefox or Google Chrome.
Saluts
Same issue with Firefox and Chrome.
The Truth is out there ?
I find that SeaMonkey works with all Cisco http access. You will need to install Java as well.
Julio E. Moisa
Please check this link, it could be useful:
https://supportforums.cisco.com/discussion/11341186/using-web-console-if-possible-manage-2960-switch
Managing the Switch
After completing Express Setup and installing the switch in your network, you can use one of these options for further configuration.
Using Device Manager
The simplest way to manage the switch is by using Device Manager in the switch memory. This web interface offers quick configuration and monitoring. You can access Device Manager from anywhere in your network through a web browser.
Procedure
    Step 1   Launch a web browser on your PC or workstation.
    Step 2   Enter the switch IP address in the web browser, and press Enter. The Device Manager page appears.
    Step 3   Use Device Manager to perform basic switch configuration and monitoring. See the Device Manager online help for more information.
    Step 4   For a more advanced configuration, download and run Cisco Network Assistant, which is described in the next section.
    Reference: http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/hardware/quick/guide/b_gsg_2960xr.html
    >> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
    I check your link, the iOS update already done integrate html folder (it's a DEV MGR version).
    As i say previously, only https is not working, http is working if i active it.
    Hello
    @Elrick Landon wrote:
    HIf i active https => HTTPS KO, telnet on port 443 is open, but Nothing is answering behind.
    You have http-telnet access so can you elaborate what you mean by this? -
    What are you trying t access and by what means, http-telnet etc...?
    Kind Regards
    Paul
