Cisco 2970G and HSRP
l-rinetti
I'm in doubt if the 2970G is supporting HSRP, from a search in the Feature Navigator i have not found an IOS with this feature.
Can you make me clear if there is an IOS image supporting HSRP on this switch ?
You can get a 3560G with IP base license:
Cisco Catalyst 3560G-24TS: 24 Ethernet 10/100/1000 ports and 4 SFP-based Gigabit Ethernet ports; 1RU
here is the data sheet:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3560-series-switches/product_data_sheet09186a00801f3d7d.html
Reza Sharifi
2970 series switches are just layer-2 switches and do not support HSRP.
Thank You,
At this point what (cheap) switch can you suggest with:
24GE ports (1000BaseT)
2 GE uplink/trunk port
IP and HSRP feature-set ?
The Product(3560G-24TS) is EoS and the replacement for the same is WS-C3560X-24T-S.
Kindly refer http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-series-switches/eol_c51-696372.html
Kind Regards,
ThiyaguVG.
