Multiple unmanaged switches, single subnet, connected to Cisco 2960 or 2901?
Chad Elder
I have a vendor installing 32 IP cameras and 2 network video recorders.  All 34 devices are on the same subnet and connected across three 10/100 unmanaged switches.
I have an existing LAN including a Cisco 2960 switch and 2901 router.  I would like to connect each of the unmanaged switches to the existing LAN individually so that each unmanaged switch isn't tethered to the next with 10/100 throughput bottlenecks.
Can this be done between multiple unmanaged switches and my 2960 or perhaps my 2901 with a 4-port Ethernet switch EHWIC?
Leo Laohoo
Don't.  Just don't.
There's a reason why the vendor connected the cameras to a separate LAN:  MULTICAST.
There's a significant chance that once you migrate those cameras to a managed network, your cameras will go nuts.
Be careful when you do this.  You need to closely research on the multicast requirements, QoS, etc.
The IP camera network subnet could be segmented at layer 2 on our 2960 or both layers 2 and 3 on the 2901.  Would that not mitigate the multicast concern?
