Cisco 3550 and Wireless Access Points
Chris Whiteley
Hello All,
I am hoping someone can help me with insight on what I can do to accomplish my end goal of safe public wifi and configuration.
I have 2 domain controllers (for redundancy) with a split scope for DHCP and they both serve DNS.
I have VLAN 2 (management), VLAN 3 (Servers), VLAN 4 (Wired Access), VLAN 6 (Wireless Access) and VLAN 480 (Outside Wireless).
I have setup INT VLANs for all of these on my main router (Cisco 3550) with the ip-helper address to the DC for all but the VLAN 480. All of this works great, and the scopes are setup just like the VLANs. (ie 192.168.2.0 (management) .3 (servers) etc.)
I was wondering if there is a way to have VLAN 480 get DHCP from the cisco 3550 as a random address say, 172.16.0.0 255.255.248.0?
On a side note, I have seperate Wireless Access Points for the outside. (From a guy before me) I understand you can have a guest wireless setup on the newer Access Points, and trunk (cisco term) the 2 VLANs and seperate them out with Access Control Lists so they don't talk to each other, but I would rather just give the VLAN 480 it's own DHCP from the router.
Is this possible or am I just thinking about this too much?
Thanks for any comments!!
Hello Chris,
First of all dont be sorry for asking - this is what CSC is for- There is so much technical support for free on here you should be able to find a solution to most networking problems.
regards your queries, Yes apply the secondary address on the
3550
interface Vlan480
description Outside Wireless
ip address 172.16.0.1 255.255.255.0
ip address  10.10.1.1 255.255.255.0 secondary
wlan ap - 10.10.1.2 255.255.255.0
configure terminal
ip dhcp excluded-address 10.10.1.1  10.10.1.2
ip dhcp pool vlan 480
network 10.10.1.0 255.255.255.0
lease 10
default-router 10.10.1.2
end
res
paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
14 Replies 14
Gregory Snipes
Level 4
Level 4
I am not sure I fully understand your need, but if you are just asking if you can have your 3550 act as a DHCP server for that VLAN, the answer is a definite yes.
Here is a configuration guide for setting up a DHCP server in IOS. If this is not what you are looking for or you need any further assistance with this, let me know.
Best Regards,
Greg
I am going to attach a very very rough outline of my network and my end goal. With at the end of my access switch 2
WAP's.
Leo Laohoo
On VLAN 480, stick a secondary IP address of 172.16.0.X 255.255.248.0.
Here is my switch config. Let me know if I am doing this right or not
#sh run
Building configuration...
Current configuration : 10787 bytes
! Last configuration change at 17:28:14 PDT Sun Oct 7 2012 by admin
! NVRAM config last updated at 16:52:35 PDT Tue Aug 7 2012 by admin
version 12.2
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname Switch
logging buffered 16384
no logging console
enable secret 5 $1$JwuS$pZzOBIIyfkICo2bionMs40
username admin privilege 15 password 7 113B2F3544071B1C54383F
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PST -8
clock summer-time PDT recurring
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery interval 400
ip subnet-zero
ip routing
ip name-server 192.168.3.21
ip name-server 192.168.3.22
ip dhcp excluded-address 172.16.0.1
ip dhcp pool GuestWLAN
   Network 172.16.0.0 255.255.248.0
   Default-router 172.16.0.1
   dns-server 8.8.8.8 8.8.4.4.4
crypto pki trustpoint TP-self-signed-1707699712
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1707699712
revocation-check none
rsakeypair TP-self-signed-1707699712
crypto pki certificate chain TP-self-signed-1707699712
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31373037 36393937 3132301E 170D3131 30313035 31333139
  32375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37303736
  39393731 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B5D9 FFF52E45 9792108A 049792F2 FADF1086 3B96E2DC 135B98A3 2B2F84B7
  935C763A A47B3AA5 DF7F4E06 401E2F5C 5201B1F5 4CBE97EE 5C572736 5429AE5D
  5D160311 5061B6C1 CBED14FA D203A802 5E891603 52D6FF93 5EA34D6F 515F9360
  DD5A4549 8E051E13 225F5597 6EF931F0 C527A727 AB531C9F 59D840B0 7FF7502E
  1E5D0203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17727670 2D72656D 6F74652D 312E7276 646F6373 2E6E6574
  301F0603 551D2304 18301680 140DE10A E69572F5 95BF5CC7 52935ACA 1DDFDB2B
  75301D06 03551D0E 04160414 0DE10AE6 9572F595 BF5CC752 935ACA1D DFDB2B75
  300D0609 2A864886 F70D0101 04050003 81810055 1D10804C FDB2A4E9 64FF1DB9
  425AA2B9 E1058E58 BF1B7373 C9B8BBA7 44C80C87 F5967E63 838ED60D D38FD20F
  2376660F B662C479 0EC21793 715EB681 349D60FA EA71C63A 9DD68240 5AC83801
  A4C4BC29 FF5FC2AC 60D8BBAA 42E95578 6106086F 42339BED 66E8024B E23933D4
  5A579CBE 0E5588D9 A9422731 A2E3F2DD 715DE7
  quit
spanning-tree mode rapid-pvst
spanning-tree portfast bpduguard default
vlan internal allocation policy ascending
interface FastEthernet0/47
description Inside Wireless AP
switchport mode access
switchport access VLAN 6
interface FastEthernet0/48
description Outside Wireless AP
switchport access VLAN 480
interface Vlan1
no ip address
shutdown
interface Vlan2
description Management
ip address 192.168.2.1 255.255.255.0
ip helper-address 192.168.3.21
interface Vlan3
description Servers
ip address 192.168.3.1 255.255.255.0
interface Vlan4
description Wired Access
ip address 192.168.4.1 255.255.254.0
interface Vlan6
description Wireless Access
ip address 192.168.6.1 255.255.254.0
interface Vlan13
description Inside
ip address 192.168.13.1 255.255.255.0
interface Vlan480
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.13.2 (Pointing to Cisco ASA 5505)
no ip http server
ip http secure-server
Hello chirs,
Is there a reason why you dont wont to create a new dhcp scope  on the exisiing dhcp servers for vlan 480?
res
Paul
Kind Regards
Paul
I don't want the outside wireless to go through the network at all. I want it to go from the access point, trunked to the router, trunked to the cisco asa 5505 and out. I don't want anyone on the outside using the internal DHCP or DNS servers.
Hello Chirs,
So you can do as lealaloo has suggested and  add a secondary ip address on the 3350 svi 480 and set the outside WLAN AP a dhcp server.
res
Paul
Kind Regards
Paul
I am so sorry to ask this of you, but could you show me via some code as to where the secondary IP address is supposed to go? Are you talking about just setting the IP address of the interface, and then on the Access Point itself change it to DHCP, so that the AP is giving it out and not the switch?
Hello Chris,
3550
interface Vlan480
configure terminal
lease 10
end
res
paul
Kind Regards
Paul
What if my access point are just some horrible Linksys WRT54g's? I don't think I can configure them this way...unless I probably installed DD-WRT on them. I guess I was hoping to turn those into just access points, and not setup dhcp on them, but if there is no way to set the router to give DHCP to only 1 vlan and not the others, than I guess this is the only option I have.
Hello chris,
Yes of course you can, I was assuming your aps were cisco, but If the ap's are no cisco or not able to support the dhcp service  then you can enable it on your switch instead.
res
Paul
Kind Regards
Paul
So how would I accomplish this?
int vlan 480
ip address 192.168.2.5 255.255.255.0
ip address 172.16.0.1 255.255.248.0 secondary
is this correct?
Chris,
conf t
int vlan  480
ip address
172.16.0.X 255.255.248.0 secondary
end
Chris Whiteley
I have figured out my issue... I had the dhcp pool and everything setup correctly, however I had my access list backwards. I had:
access-list 199 deny ip 192.168.0.0 255.255.224.0 any instead of
access-list 199 deny ip any 192.168.0.0 255.255.224.0
Thanks for all your guys help!
