How to setup SPAN on 4900m Switch
Hey there,
I currently have IOS image cat4500e-entservices-mz.122-53.SG5.bin.  According to my research it appears SPAN is supported on this OS.  However, after looking at procedure notes using websites like here:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml#topic4 I cannot find and obviously not figure out how to use the SPAN  command.  My main objective is to simply setup a port mirror on one of my TenGigabitEthnet interfaces and from what I read SPAN is the best way to setup a tap interface on a cisco switch.  Any ideas or suggestions on how I can get SPAN to work or some other type of alternative I would be very grateful.
Dan Martin
kcnajaf
Level 7
Level 7
Hi Dan,
You can use below commands.
config terminal
monitor session 1 source interface TenGig x/x  (This is port which you want to monitor)
monitor session 1 destination interface TenGig xx/xx (The port on switch packet capture software will be running)
You can verify the session with show monitor session 1 command.
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
Hi Dan,
config terminal
Hope that helps.
Najaf
Hey Najaf,
Thank you for your response.  I actually also found the correct answer in the cisco guide pdf for 4500 switches.  The links I originally looked at indicated to me there was an actual SPAN command but it looks like monitor is the command.  Anyhow, thanks again for your assistance.
Dan
