Cisco 3560 - clear it's configuration
djgizmo250
How do I clear it's configuration? I tried 'delete flash:vlan.dat' and 'delete flash:config.text', but neither worked. Please help.
8 Replies 8
Edison Ortiz
try write erase and reload.
delete flash:vlan.dat is also useful to clear the vlan database.
I tried write erase and reloaded it, but the host name and configuration was still there.
please post the output from show version and show boot
Here is the sh ver and sh boot:
[hostname]#sh ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.1(19r)EA1b, RELEASE SOFTWA
RE (fc2)
[hostname] uptime is 1 minute
System image file is "flash:/c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.
SEB4.bin"
cisco WS-C3560-48PS (PowerPC405) processor (revision H0) with 118784K/12280K byt
es of memory.
Processor board ID CAT0848R0AW
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Version ID : N/A
Hardware Board Revision Number : 0x0C
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560-48PS 12.2(25)SEB4 C3560-IPBASE-M
Configuration register is 0xF
[hostname]#sh boot
BOOT path-list : flash:c3560-ipbase-mz.122-25.SEB4.tar
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
[hostname]#
Usually when you reload it will ask you if you want to save the config , if you said yes then you overwrote the empty startup config with the running config.
Here is my output for when I delete config.text and reload:
[hostname]#delete config.text
Delete filename [config.text]?
Delete flash:config.text? [confirm]
[hostname]#reload
Proceed with reload? [confirm]
*Feb 28 17:04:15.982 PST: %SYS-5-RELOAD: Reload requested by console. Reload Rea
Ok. I figured it out. I now have a clear config.
Thanks guys!
Please share what was done to correct the problem.
