Cisco 3560 switch replacement
muresan.andrei
Hi there,
I am searching for a Cisco switch that provide layer 3  features for a local network. Currently i use a 3560 8 ports model and I need something with the same characteristics but having all ports as Gigabit ports.
Thanks for helping !
Cheers !
Feauture:WS-C3560CG-8PC-S
Routing Protocol:OSPF, RIP-1, RIP-2, OSPFv2
Other fetures....
DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Dynamic ARP Inspection (DAI), PoE+, STP Root Guard, Uni-Directional Link Detection (UDLD), fanless, DHCP relay, Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN)
Please rate if it helps.
5 Replies 5
glen.grant
  Just go on cisco's main webpage and look up products. All the data is right there . Most switches are all gig now .  There aren't  many models that are still just 10/100 interfaces  including the latest 3560 switches.
I found the 3560-x series, but they don't offer a model with only 8 ports. Another option is the 3560-C family with the
3560CG-8PC-S refference, but for this one i'm not sure if it offers the same features as the old 3560 version that i currently have. Can you confirm that this refference will offer me ip routing, vlan functionality, QoS, ...
Thanks!
Other fetures....
Do you know if this is the cheapest solution from Cisco that can offer the features above ?
Thanks!
I do not know about the price but as per my knowledge you will get it in 950$ , it depends on you .....how many ports switch do you need.
if 8 or less then 8 then it will be better .......
