stftp on 3750-x
Patrick McHenry
Level 4
Level 4
Do I need the Universal image to perform stftp on a 3750 or3750-X?
Thanks, Pat.
8 Replies 8
Leo Laohoo
No but you need to use the IOS that supports Crypto.
Leo,
I don't see an option for stftp.
Switch-3750X-48-Stack(config)#archive
Switch-3750X-48-Stack(config-archive)#path ?
  flash1:  Write archive on flash1: file system
  flash:   Write archive on flash: file system
  ftp:     Write archive on ftp: file system
  http:    Write archive on http: file system
  https:   Write archive on https: file system
  rcp:     Write archive on rcp: file system
  scp:     Write archive on scp: file system
  tftp:    Write archive on tftp: file system
Is it one of these options?
Image:
flash:/c3750e-universalk9-mz.122-55.SE1/c3750e-universalk9-mz.122-55.SE1.bin"
Thanks, Pat.
My apologies Pat.
I believe "scp" is the only one supported.
No prob - how do I use SCP?
I want to use the archive command to automate config saves but I want to do it securely. Does this work the same way as tftp? For instance, would I send the config file to an SCP server sitting somewhere on the network the same way I would send a file to a tftp server?
For example:
config t
archive
path scp:..............
Know of a doc?
Thanks, Pat.
Can you do a ? after path on your switch?
Switch(config-archive)#path ?
I don't see scp, but than again my version is probably different than yours
Switch-3750X-48-Stack(config-archive)#path scp:?
  scp:  A URL beginning with this prefix
Thanks, Pat.
The only command I see is this:
path scp:// username:password@ip_address_scp/3750G
- write-memory
Have a look:
http://www.solarwinds.com/search/cisco-3750-username.aspx
Does the switch you are working on have a username/password configured?
I was thinking the url was going to be the address\drive\folder name\filename..... of the remote scp server.
I've set this up with tftp and it worked great. Now, I want to set this up so it is secure.
Do you know of any docs that explain not only the Cisco side but also the server side including the scp client used?
Thanks, Pat
