Cisco 3560CX Not booting after updating firmware
bcramer04
I have a 3560CX that is stuck at the switch: prompt when it boots up.
switch: set
ARCADIA_PORT_IS_QUAD_UPLINK=0
BOARD_CONFIG_REV=3
BOOT=ucode0:
CLEI_CODE_NUMBER=CMM1V10DRB
IMAGE_UPGRADE=yes
MAC_ADDR=EC:CE:13:BB:3A:80
MODEL_NUM=WS-C3560CX-12PD-S
MODEL_REVISION_NUM=R0
MOTHERBOARD_ASSEMBLY_NUM=73-100860-04
MOTHERBOARD_REVISION_NUM=D0
MOTHERBOARD_SERIAL_NUM=FOC2449272V
POWER_SUPPLY_PART_NUM=341-0675-02
POWER_SUPPLY_SERIAL_NUM=LIT24352AAR
RESET_REASON=Reload command
SDM_TEMPLATE_ID=0
SWITCH_NUMBER=1
SWITCH_PRIORITY=1
SYSTEM_DOWNSHIFT_CFG=1
SYSTEM_DOWNSHIFT_COUNTER_CFG=3
SYSTEM_SERIAL_NUM=FOC2451L696
TAN_NUM=68-100569-01
TAN_REVISION_NUMBER=H0
TERMLINES=0
VERSION_ID=V04
boot=usbflash0
How can I get an IOS loaded on it?
bcramer04
After copying over the IOS the Cisco now boots.
6 Replies 6
marce1000
 - Is there a valid image on the system already or are you trying to boot from usb ?
 M.
bcramer04
I don't believe there is. I'm currently trying to do this command but it might be a while.
copy xmodem: flash:c3560cx-universalk9-mz.152-7.E7.bin
   - Keep us updated and or mark as resolved (...if applicable...) ,
 M.
balaji.bandi
3560CX has USB, why not use USB to boot the image, once booted using USB . you can copy to flash and set up boot variable.
BB
bcramer04
I initially tried using USB but it wasn't showing the IOS when I tried using the dir flash command.
bcramer04
