cisco 3650 DC power to AC power
veeru.pardeep
Hi everyone,
I am faced with a hardware dilemma and maybe someone could help me. Recently, some older Cisco 24-port switches (3560V2) have been relocated to our department. The problem is that these are DC switches... Is there any possibility to change the DC power supply with an AC power supply? If it can be done, could someone help me with a part number? In case changing the power supply is not possible, is there some sort of adapter that can be used instead?
what is the exact switch model.  if it is swappable, we can change. let us know exact switch model part code
Good luck
KB
balaji.bandi
3560V2  - these models are end of life long back, as I believe these are fixed PSU inside the Box,
The best is to get AC to DC Converter and test it one device see all ok, before you order many, you get many in the local market to make it work.
reference :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/hardware/installation/guide/3560hig/higdcpwr.html
Or check you can get used RPS in the market to powerup all switches :
https://www.cisco.com/c/en/us/products/collateral/switches/redundant-power-system-2300/product_data_sheet0900aecd805bbef6.html
BB
