Cisco 3725 Hardware help needed
glenthms
I'm trying to determine how many WIC T1/CSU interfaces I can fit into my 3725 router. Can someone help me find a tool on cisco's site that assists with this? I currently have 2WIC and 2FE but can't really tell if they're built in, combo card or what. I have attached the show diag, show ver, and show hardware outputs.
spremkumar
Level 9
Level 9
You can make use of the below link to find out the modules which can fit onto your box as well as the required ios code to have in your box...
http://tools.cisco.com/Support/Fusion/hcchecksupport.do
Below link gives you and insight view of the models supported in Cisco 3700 series routers..
http://www.cisco.com/en/US/products/hw/routers/ps282/products_data_sheet09186a008009203f.html
regds
