Cisco 3750 and Pagp parameters on interfaces
i have a 3750 Stack with two switches. The IOS version on this machines is the c3750-ipbasek9-mz.122-37.SE1.bin one
The IOS is installed on different switches but on this couple i have a trouble.
A normale switch port has the following part of the configuration:
Interface FastEthernet 2/0/15
pagp learn-method physical-port
pagp timer 17671
end
If we delete the entries with the command:
no pagp learn-method physical-port
no pagp timer 17671
the interface doesn't display them...but after 30 seconds or 1 minute i find again the two lines...
Obviously there are portchannels configured on the stack!!!
What happens?
Thanks for the answer
andtoth
Level 4
Level 4
