12-19-2011 07:27 AM - edited 03-07-2019 03:58 AM
Hello all,
I have an issue where I'm seeing output discards on pretty much all my ports configured for QoS. The switches are cisco WS-C3750V2-48PS running 12.2(50)SE1. There are four switches stacked using stack cables. The QoS implemeted was auto-qos with no modifications to the standard config. All ports are in queue-set 1. The phones connected are Cisco 7942's. Already did the standard check for speed duplex mismatch, crc's, runts, giants, etc...No discards before the QoS was applied. No bug ID's I could find regarding these switches and this IOS version. The one thing noticed is that 99% of all the drops are from queue's 2 and 4 or 1 and 3 doing the below command. Looking for any ideas.
**I've limited the cut and paste as to not clutter the discussion until someone requests something else**
James
show platform port-asic stats drop
Port 18 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 1852
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 57788
interface FastEthernet1/0/18
switchport access vlan 100
switchport voice vlan 101
speed 100
duplex full
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust device cisco-phone
mls qos trust dscp
auto qos voip cisco-phone
12-19-2011 08:56 AM
Please post the output from typing:
show mls qos interface fa1/0/18 statistics
and
show mls qos maps
12-19-2011 09:44 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Enabling QoS on a 3750 splits buffer resources across 4 queues instead of just 1 queue. Likely the default buffer re-allocations doesn't well support your traffic in the 4 queues. You may be able to mitigate the problem by re-assigning buffer resources, but that's not guaranteed.
12-21-2011 03:03 PM
James,
I am also running 122(50) SE1 on some of my switches, I notice in your interface configuration there is not
"service-policy input AutoQoS-Police-CiscoPhone" which is one of the things generated by the Auto Qos command.
with the sh platform port-asic stats drop
I get the following; BTW the switch has been up 33 weeks, so really not that many drops, most of the Ip phones are 7962s
I am just wondering if it is working as it should, what sort of PC traffic do you have on your interfaces, does anybody complain about slowness etc?
Port-asic Port Drop Statistics - Summary
RxQueue 0 Drop Stats: 0
RxQueue 1 Drop Stats: 0
RxQueue 2 Drop Stats: 0
RxQueue 3 Drop Stats: 0
Port 0 TxQueue Drop Stats: 0
Port 1 TxQueue Drop Stats: 0
Port 2 TxQueue Drop Stats: 535404
Port 3 TxQueue Drop Stats: 7149
Port 4 TxQueue Drop Stats: 8572
Port 5 TxQueue Drop Stats: 3011
Port 6 TxQueue Drop Stats: 0
Port 7 TxQueue Drop Stats: 66760
Port 8 TxQueue Drop Stats: 0
Port 9 TxQueue Drop Stats: 5983
Port 10 TxQueue Drop Stats: 5867
Port 11 TxQueue Drop Stats: 0
Port 12 TxQueue Drop Stats: 7102
Port 13 TxQueue Drop Stats: 0
Port 14 TxQueue Drop Stats: 0
Port 15 TxQueue Drop Stats: 2083
Port 16 TxQueue Drop Stats: 419
Port 17 TxQueue Drop Stats: 44784
Port 18 TxQueue Drop Stats: 2300
Port 19 TxQueue Drop Stats: 10876
Port 20 TxQueue Drop Stats: 2271
Port 21 TxQueue Drop Stats: 57697
Port 22 TxQueue Drop Stats: 52418
Port 23 TxQueue Drop Stats: 24695
Port 24 TxQueue Drop Stats: 1729
Port 25 TxQueue Drop Stats: 3720
12-22-2011 06:50 AM
Here are the stats after changing the SRR settings yesterday from 10.10.60.20
interface FastEthernet1/0/24
srr-queue bandwidth share 10 20 10 60
priority-queue out
mls qos trust dscp
spanning-tree portfast
YOW02-SWM-001#show platform port-asic stats drop fastEthernet 1/0/24
Interface Fa1/0/24 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 31512
Weight 1 Frames 0
Weight 2 Frames 1853
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 66351
12-22-2011 07:19 AM
Wait a minute. These may be old stats as I don't think you can clear the show platform counters like you can the show mls counters.
