cisco 3750-Flash not detected
youness10
Hello ;
I have a 3750G switch that it has flash not detected on Roman mode, I try flash_init and dir flash: but no look as below :
switch: flash_init
Initializing Flash...
...The flash is already initialized.
switch: dir
List of filesystems currently registered:
bs[0]: (read-only)
xmodem[3]: (read-only)
null[4]: (read-write)
Can anyone help me fix that issue .
9 Replies 9
Leo Laohoo
@youness10 wrote:
switch: dir
The syntax is incorrect.  Try "dir flash:".
I already do it, but I get
switch: dir flash:
unable to stat flash:/: no such device
Ok, console into the switch and reboot the switch.
Post the entire bootup process.
Using driver version 1 for media type 1 Base ethernet MAC Address: 04:c5:a4:dc:e3:80 Xmodem file system is available. The password-recovery mechanism is enabled. Initializing Flash... mifs[2]: 0 files, 1 directories mifs[2]: Total bytes : 3870720 mifs[2]: Bytes used : 1024 mifs[2]: Bytes available : 3869696 mifs[2]: mifs fsck took 0 seconds. mifs[3]: 0 files, 1 directories mifs[3]: Total bytes : 27998208 mifs[3]: Bytes used : 1024 mifs[3]: Bytes available : 27997184 mifs[3]: mifs fsck took 1 seconds. ...done Initializing Flash. done. Loading "flash:c3750-ipbasek9-mz.122-50.SE4.bin"...flash:c3750-ipbasek9-mz.122-50.SE4.bin: no such file or directory Error loading "flash:c3750-ipbasek9-mz.122-50.SE4.bin" Interrupt within 5 seconds to abort boot process. Boot process failed... The system is unable to boot automatically. The BOOT environment variable needs to be set to a bootable image.
Can you try to post the complete output to the command "set"?
Hello ,
As demand ; below is the output fo set command :
switch: set
BAUD=9600
BOARD_CONFIG_REV=0
BOOT=flash:c3750-ipbasek9-mz.122-55.SE12.bin
CLEI_CODE_NUMBER=COMP600ARA
DBRD_PIXAR2TITANIUM_ASSEMBLY_PART_NUM=73-11329-02
DBRD_PIXAR2TITANIUM_REVISION_NUM=B0
DBRD_PIXAR2TITANIUM_SERIAL_NUM1=FDO14330DLA
DBRD_PIXAR2TITANIUM_SERIAL_NUM2=FDO14330DLP
MAC_ADDR=68:BD:AB:31:BF:80
MODEL_NUM=WS-C3750V2-48PS-S
MODEL_REVISION_NUM=H0
MOTHERBOARD_ASSEMBLY_NUM=73-11705-12
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FDO143310Y5
POWER_SUPPLY_PART_NUM=341-0266-02
POWER_SUPPLY_SERIAL_NUM=DCA1430H93N
SDM_TEMPLATE_ID=0
SWITCH_NUMBER=1
SWITCH_PRIORITY=1
SYSTEM_SERIAL_NUM=FDO1433Z11N
TAN_NUM=800-31041-05
-- MORE --
TAN_REVISION_NUMBER=A0
VERSION_ID=V05
confreg=
Ok, last try ...
1. Reboot the appliance; and
2. Try the command again "dir flash:".
If the problem still persist, try the command "format flash:".
And when it says "are you sure", enter "y".
Wayne DeNardi
As mentioned by Leo, if you want to look at the files in the flash, you need to specify the flash: as part of the dir command, ie dir flash:
See https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html for some examples.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hi Wayne ;
I did dir flash: and I get
switch: dir flash:
