Cisco 3750 input rate does not display on routed port
mmedwid
Level 3
Level 3
But I have a 3560 at another site with a routed port and input and output rate do display with sho interface command.  The 3750 is running
12.2(46)SE and the 3560 12.2(53)SE2.  Is the difference in the code version or is that the 3560 can display in/out bps on a routed port
and 3750 can not?  Thanks.
6 Replies 6
John Blakley
I have the same version, but I see the input rate on the interface. Can you post what you're seeing?
HTH, John *** Please rate all useful posts ***
Pay no attention to collisions - those were from initial setup.  There is always traffic on this circuit and it is visible via SNMP as I can graph the port with Solar Winds.  But yet the show int shows me 0's.  ??
hrk-c3750-1#sho int gi 1/0/6
GigabitEthernet1/0/6 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0022.56ae.81c6 (bia 0022.56ae.81c6)
  Description: Cogent L2 to SFO
  Internet address is 10.10.7.53/30
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 0/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1573343
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     4857204826 packets input, 134056628648 bytes, 0 no buffer
     Received 17776072 broadcasts (0 IP multicasts)
     3 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 8 multicast, 0 pause input
     9005089729 packets output, 3374212630325 bytes, 0 underruns
     0 output errors, 15175 collisions, 9 interface resets
     0 babbles, 10373 late collision, 0 deferred
interface GigabitEthernet1/0/6
description Cogent L2 to SFO
no switchport
ip address 10.10.7.53 255.255.255.252
speed 100
duplex full
sho ver:
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Hey,
Is this only happening with a singular routed port on this switch (Gi1/0/6)?
/Thanks
Pronoy
There are three routed ports in the stack of two 3750s.  All three are showing no traffic with the show interface command.  Switched ports display all stats as expected.
Looks to be a software bug then, since as you said previously, that the interface does have a lot of traffic flowing through it.
Thoughts?
I am going to try and check if I do have one handy or not.
Would keep you posted.
Came across a bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsz18634
Could you check this out?
Looks to be resolved in 12.2(53)SE.
Pronoy
(Please rate useful posts)
