cisco 3750 switch stacking
Sarg .
Level 3
Level 3
guys i have a cisco 3750 switch stacked together that i need to copy configs from and transfer to another set of two 3750 stack switches.
do i simply connect the stacking cable to the switch with the highest mac address and then to the second one, then copy the old running configurations. is there more that i need to do ?
6 Replies 6
Leo Laohoo
Copy the configuration from your existing 3750 stack into your TFTP server, edit the config to suit your needs, and copy the newly-edited-config into your new stack.
Command:  copy flash1:config.text tftp:///filename.extension
Command above is to copy the config from your existing switch stack to your TFTP server.
Command:  copy tftp:///filename.extension run
Command above is to copy from your TFTP server to the running-config of your new switch.  Remember, the config is not yet saved.
Thanks Leolaohoo,  The stacking went fine but there is a problem. The problem is that some of my access-ports are constantly flopping.
when i issue the command show log i see ' line protocol down' and then, ' line protocol' up.
I have considered that it could the be the stacking cable but when i sssue the ' show switch' command both my 3750 switches in the stack have a status of ' ready' . other users on the switch seem to be fine. but a few users keep getting the same problem of their ports flapping.
Kindly post the output to the following command:
1.  sh version;
2.  sh switch detail;
3.  sh post; and
4.  sh log
ok i will do that on monday. Thanks
Thanks Leolaohoo, everything turned out ok.  It turned out some guys were playing with the network and connected non approved/ planned switches which were making a mess of the network.
Cheers
LOL!
Ooops.  Not meaning to be mean or something.  Sorry for laughing.
