Cisco 6509 Modular IOS high cpu utilization
cssam
Hi all,
Cisco 6509 modular IOS getting high cpu in interrupt but the switch process switching is still less. Any sugeestion what could be the problem?
Process sbin/ios-base, type IOS, PID = 16407
CPU utilization for five seconds: 12%/81%;
Sometimes cpu goes upto 100%
Version - s72033-ipservicesk9_wan-vz.122-33.SXH5
phiharri
Greetings,
The following CSC doc covers the netdr tool to identify traffic being sent to the CPU which is the most common cause for interrupt utilization: https://supportforums.cisco.com/docs/DOC-14086
Follow this process while the CPU utilization is raised to identify trends in the packets which aren't being software switched:
debug netdr clear
debug netdr cap rx
(wait a few seconds)
undebug all
sh netdr cap | i int
Is there one interface receiving the majority of traffic? If so - any config/feature on that interface that could require software switching (SLB, PBR, NAT, WCCP, ACL with log etc)?
sh netdr cap | i ttl
Is there an excess of traffic with TTL 1?
Are there some common destination IP/subnets?
sh netdr cap | i dest_indx
How many of the capture lines have 'flood 1' set?
What are the most common dest_indx value?
Kind Regards,
/Phil
Edison Ortiz
Any reason for running modular IOS?
Hi Phil,
I will check command outputs and update you.
hi Edison,
it came along with new cisco 6500 box. We do not have any specific reason.
How this matter is solved?
Was it related to any IOS bug such CSCsr12976
