03-29-2012 11:36 AM - edited 03-07-2019 05:51 AM
Dear Friends,
In my office we bought 7 cisco 3750X - 48PS switches. We configured Data Stacking between those switches. We also want to configure Power Stacking between those 7 devices.
I found in the Data Sheet that we can only cofigure 4 devices in power stacking at a time. If it is like that how to configure the rest of 3 devices. I need your valuable help in configuring power stacking between those devices in a better way..
Kindly help to configure them....
power stack cable part no we have is
CAB-SPWR-30CM
Vamsi Harish.T.
Solved! Go to Solution.
03-29-2012 12:30 PM
What you do in this scenarion is to create 2 powerstacks.
You can have several powerstacks in the same data stack and each of the powerstacks can have a maximum of 4 3750x.
the powercables must ofcourse not leave the powerstack ! ie the cabeling must be correctly inserted in the corresponding powerstack.
I would make it the 4 first switches in the first powerstack and the 3 bottom in the second powerstack.
Do not forget to enable the powerstack interfaces.
Here is a link on how it works.
Good luck
03-29-2012 12:30 PM
Good luck
04-08-2012 11:27 AM
Thanks for your valuable replay and also sorry for the dealy in responce. I've configured Power Stacking as you adviced. It's working fine.
Vamsi Harish.T.
E-mail:
