CISCO 3945 router compact flash issue
Hello All,
I am facing this weir issue in one of the 3945 routers we  have, when the router starts to boot there is an error, the router boots up fine but this eror is bothering me a lot
"WARNING: Unsupported compact flash detected. Use of this card during normal
operation can impact and severely degrade performance of the system.
Please use supported compact flash cards only.
program load complete, entry point: 0x4000000, size: 0x18fa0"
DEFAULT 256 MB CISCO flash card in external
the same flash card was working fine,I used it to copy IOS to another flash card of 256MB and untill then it was fine,,.
now its throwing up errors...i tried changing the slots ....formatted the flash card as well and tried..
can somebody please help me out here???please
Leo Laohoo
Is the CF in use a Cisco-branded one or not?
If not, what is the model and size of this CF?
Try a different brand will definitely help.
Thanks for replying @ LEO....
The Flash memory size is 256 MB and its a CISCO brand itself..
Model no: 16-2768-01
Also i tried with different size and brands but the warning message persist...the router boots but outputs very.rest outputs are fine..
example , when any wan interface cards are inserted it doesn't get detected in the "sh inventory" command..but the same wan interface cards gets detected in other routers...
ALso this flash was working fine earlier on the same router...I formatted the CF and tried aswell
Try a different IOS level. It could be a bug.
alright @Leo Laohoo.... thanks for the quick solution ...I willl try the same and let you know.....
