Cisco 4500 24-port Gigabit Module being picky...
Peter Ellwood
Hi Folks,
We have recently purchased a Cisco 4506 that has several Gigabit Ethernet modules installed.
One of the Ethernet Gigabit modules - a WS-X4424-GB-RJ45 - is being picky with who it talks to at Gigabit Ethernet.
If I plug a laptop into one of it's RJ45 ports using a Cat 6 cable, nothing happens.  No link light, no notification of link up or down on port statistics, absolutely nothing.
If I plug a server into the same port it works fine at Gigabit Ethernet (even using the same Cat 6 cable).
I can get the module to recognise a laptop if I fix the speed/duplex on the laptop to 100Mb/Full - but as you can imagine that doesn't help any.
I have tried this with other staff laptops from different vendors (HP / Dell / etc.) all with the same result.
The module directly underneath this module - a WS-X4448-GB-RJ45 - works fine for both laptops and servers.  We have tried swapping the module positions but to no avail.
Has anyone seen this issue before and have any recommendations on how to debug / resolve?
Regards.
9 Replies 9
Gabriel Hill
That's pretty odd.
Could you post the following from the 4506.
1. show version
2. show module
Show module output (show version coming soon): -
#show module
Chassis Type : WS-C4506
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     6  Sup II+10GE 10GE (X2), 1000BaseX (SFP) WS-X4013+10GE      JAE12460DWU
2    24  10/100/1000BaseT (RJ45)                WS-X4424-GB-RJ45   JAE0934JRBW
3    48  10/100/1000BaseT (RJ45)                WS-X4448-GB-RJ45   JAE0939LU9W
4    48  10/100BaseTX (RJ45)                    WS-X4148-RJ        JAE07390941
5    48  10/100BaseTX (RJ45)                    WS-X4148-RJ        JAE0739094Y
M MAC addresses                    Hw  Fw           Sw               Status
1 0019.2f23.e000 to 0019.2f23.e005 1.5 12.2(31r)SGA 15.0(2)SG6       Ok
2 0013.6047.93b8 to 0013.6047.93cf 1.7                               Ok
3 0015.632e.ef60 to 0015.632e.ef8f 1.2                               Ok
4 000d.bd80.ff40 to 000d.bd80.ff6f 3.1                               Ok
5 000d.65ed.ba90 to 000d.65ed.babf 3.1                               Ok
Show version: -
#show ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 15.0(2)SG6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 31-Oct-12 13:38 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x120921B8
ROM: 12.2(31r)SGA
Pod Revision 14, Force Revision 31, Tie Revision 32
NCSRTR01 uptime is 0 minutes
System image file is "bootflash:cat4500-ipbasek9-mz.150-2.SG6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4506 (MPC8540) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX10320189
MPC8540 CPU at 667Mhz, Supervisor II-PLUS-10GE
Last reset from PowerUp
11 Virtual Ethernet interfaces
96 FastEthernet interfaces
76 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Edit: Updated with show version information
Leo Laohoo
Sound like you have a cable problem.
When you connect a problem to a laptop and then you change the interface to "speed auto 10 100", does the port go up?
Hi leolaohoo,
You'd think so but we've tried different cables to no avail.
We even tried the same cable connected to a server (works) then connecting to a laptop (doesn't work), so I'm not convinced it's a cable problem.  Will try the speed auto 10 100 shortly.
ok when connecting a laptop with the 'speed auto 10 100' the interface comes up at 100Mb.
#show int gig 2/1
GigabitEthernet2/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 0013.6047.93b8 (bia 0013.6047.93b8)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000-TX
  input flow-control is off, output flow-control is off
  Last input 00:00:01, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 2 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     99 packets input, 10640 bytes, 0 no buffer
     Received 93 broadcasts (53 multicasts)
     15 packets output, 4281 bytes, 0 underruns
     0 lost carrier, 0 no carrier
Either your laptop doesn't support 1Gbps or you have a cable issue, particularly the fourth pair or pair "D".
Try to run a TDR.   Be aware that you are using a 4500 and the "wait" from the test command to the show command could be as long as 61 seconds.
Hi leolaohoo,
Just to be clear - this isn't only happening to my laptop.  As mentioned in the first post, we already tried different laptops from my colleagues and they all experienced the same issue.  Oh and the gigabit works fine on the laptop when connected to our 2960 or 3650 switches, even to the gigabit ports in the other line cards - just not this line card.
However I have tried to run a TDR and unfortunately the line cards we have do not appear to support them: -
C4K_IOSDIAGMAN-4-TESTNOTSUPPORTEDONMODULE: Online cable diag tdr test is not supported on module 2
Edit: Added detail about gigabit working on the laptop when connected to other devices
Ok, you got me stumped.  The only thing left is an IOS bug.
Peter Ellwood
ok folks I have it figured out.  As we couldn't see anything on the switch I went to the laptop in question and disabled every funky feature on the NIC so it didn't try and do anything fancy.
Waddya know, the link came up at Gigabit.
So I turned each feature on 1-by-1 to see which feature was causing the problem and the culprit is 802.3az (Energy-Efficient Ethernet) - see http://en.wikipedia.org/wiki/Energy-Efficient_Ethernet
For some reason the 24-port line module does not like 802.3az but the 48-port line modules work with it fine.
This also explains why the servers would work but the laptops wouldn't - almost all laptops would come with 802.3az drivers these days to ensure better battery life, however I doubt any servers would have this extension.
Oh well, live and learn.  Hope this helps someone else out there.
Thanks leolaohoo for trying to help, much appreciated.
