WAN issue
Hi Team,
We have some WAN router(ASR), We are getting some error logs like below....
Please try to help me why we are getting this kind of error....is it any major?....
Jan  7 10:47:30.482: %ASR1000_PEM-3-PEMFAIL: The PEM in slot 0 is switched off or encountering a failure condition.
Jan  7 10:47:30.817: %ASR1000_PEM-6-PEMOK: The PEM in slot 0 is functioning properly
Jan  7 10:47:30.985: %ASR1000_PEM-3-PEMFAIL: The PEM in slot 0 is switched off or encountering a failure condition.
Jan  7 10:47:31.992: %ASR1000_PEM-6-PEMOK: The PEM in slot 0 is functioning properly
Jan  7 10:47:34.928: %ASR1000_PEM-3-PEMFAIL: The PEM in slot 0 is switched off or encountering a failure condition.
Milan Rai
Hey Senthil
It seems that your PEM (Power entry Module) is having some problem........As you said its ASR WAN router if its possible why dont you check out the module ..........
And if you have failover power system...just remove the one and plug it back again......one after the another....
Dont forget to Rate if it helps you..........
And let me know if it doesn't...
