01-17-2019 11:38 AM - edited 03-08-2019 05:04 PM
I have a 4510R+E and the redundant supervisor has old IOS code that is older than the IOS on the active sup, With both plugged in the standby sup is disabled and thus I cannot copy the active IOS to the standby to make them the same. How can I get the IOS thats on the active sup to the standby when I cannot access it. When I console into the standby I get nothing, I have rebooted the standby and can see it load up and see the IOS is way older than the Active, it eventually boots up but I cannot do anything on it. idea's?
Solved! Go to Solution.
01-17-2019 09:34 PM
@dkoch wrote:
I was wondering if I rebooted the standby, broke the boot cycle and from rommon mode was able to upgrade the IOS
If you can break the boot cycle into ROMmon this means that you are physically near the supervisor card. If this is the case, the fastest way is to upgrade the IOS using the Mgmt interface of the card.
01-17-2019 12:47 PM - edited 01-17-2019 12:48 PM
Do you have a spare chassis to put the second sup in it and upgrade it?
The other option maybe is to unplug the working sup (in a maintenance window) and let the chassis boot to the current standby sup, upgrade to match the other sup, configure the sup with SSO, reinsert the other sup into the chassis and reboot the chassis with both sups. If all goes well, you should see the 2 Sups in redundant mode (show redun will show you that). At this time you can switch to make the other sup the primary.
01-17-2019 01:52 PM
so outside of the 2 options, no way to upgrade it while in the current chassis? I was wondering if I rebooted the standby, broke the boot cycle and from rommon mode was able to upgrade the IOS
01-17-2019 09:34 PM
