Cisco 4500 switch reboot loop with card supervisor 6L-E WS-X45-SUP6L-E
H.youssef
Hello everyone I hope someone can help me I just choose a 4507 RE used switch and I inserted a supervisor map Engine 6 THE WS-X45-SUP6 LE but the card reboots loop (continuous reboot ) still even after I give it the Boot command in Rommon mode for booting
Any help will be appreciated.
Thanks in advance.
 * Welcome to Rom Monitor for WS-X45-SUP6L-E System.      *
 * Copyright (c) 2003-2009 by Cisco Systems, Inc.         *
 * All rights reserved.                                   *
Checking the partition table and boot sector...
Checking FAT, Files and Directories...
Reclaiming unused space...
Updating FAT...
 Rom Monitor Program Version 12.2(44r)SG5
 CPU Rev: 2.1, Board Rev: 9, Board Type: 103, CPLD Nexu Rev: 9
 Chassis: WS-C4507R-E
Front Panel Phy is Bcm5482s
Got Mac Address: 58:8d:09:49:9e:b2
 MAC Address  : 58-8d-09-49-9e-b2
 IP Address   : 192.168.10.227
 Netmask      : 255.255.255.0
 Gateway      : 192.168.10.228
 TftpServer   : Not set.
 ***** The system will autoboot in 5 seconds *****
 Type control-C to prevent autobooting.
 ******** The system will autoboot now ********
 config-register = 0x2101
 Autobooting using the first file from bootflash.....
Rommon reg: 0x00004380
Reset2Reg: 0x00008EFF
Darkside controller 0x0B435613..0x0B4439C5 original size:0x00012092##
Fortooine controller 0x0B56E584..0x0B6AA214 original size:0x001A8529
diagsk5 version 4.1.0
prod: WS-X45-SUP6L-E part: 73-13182-01 serial: JAE144100KL
Power-on-self-test for Module 4: WS-X45-SUP6L-E
 Test Status: (. = Pass, F = Fail, U = Untested)
CPU Subsystem Tests ...
 seeprom: Pass
Traffic: L3 Looopback ...
 Test Results: Pass
Traffic: L2 Loopback ...
 Test Results: Pass
Switching Subsystem Memory ...
 Packet Memory Test Results: Pass
Module 4 Passed
Rommon reg: 0x00000380
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASE-M), Version 12.2(53)SG4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Fri 25-Feb-11 15:14 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x124334BC
VECTOR D00
Buffered messages:
Queued messages:
*Mar  2 03:24:31.171: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:00:01.463: %C4K_IOSSYS-3-BLANKSTARTUPCONFIG: Blank or invalid startup-config, booting up with defaults
*Mar  2 03:24:24.243: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
Updating FAT...
5 Replies 5
stupid question maybe, but what if you hit Ctrl + C ?
I switch to rommon mode
Go to ROMmon and use a different IOS version.
marce1000
 https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsv33795/?referring_site=bugquickviewredir
M.
thanks in your response,
how remove AUDIT command.
