Bookmark
Subscribe
11552
2960X Switch Stacking with fiber
Zeeshan Shaikh
Hi All,
I am trying to stack 2960x "WS-C2960X-48LPD-L" switches in two different racks, and racks are far away from each other. ( lets say 4 Meters distance between racks).
My ask is, how I can create stack between switches using fiber cable (1000BaseSX SFP),
I am attaching the pic of closet for better under standing.
Thank you and much appreciated your reply.
Seems like Cisco is working on horizontal stacking for 2960X also:
http://www.cisco.com/c/dam/global/da_dk/assets/pdfs/cisco_catalyst_switching.pdf
10 Replies 10
Reza Sharifi
There is no stacking cable that long (4 meters).  I think the longest stacking cable is one meter.
So, the easiest way to do this is by stacking the 2 switches in rack-1 and uplink them to the core and also stack 3 switches in rack-2 and uplink them to the core.  In this case, you will have 2 stacks, one in rack-1 and one in rack-2.
Thanks Rex's for your reply,
 I don't have enough uplinks in core so can't make them separate stack.
and the longest stack cable cisco has 3 meter which is no not enough for me as well that's why trying to do it with fiber.
plz let me know if you find any solutions.
thanks and appreciated your reply.
You may want to contact this company (link below) as they have stacking cables up to 10M.
http://blog.connectzone.com/cab-stack-10m-the-longest-available-stackwise-cable-for-cisco-3750/
The pictures shows it being for the 3750 series but they may custom build for 2960x as well.
Leo Laohoo
This is called Horizontal Stacking and this feature will never be enabled on a Cat 2K.
Thanks Leo,
Do you have any other idea/ suggestions to accomplish stacking in 2 separate racks on (2960x) switches.
thank you
Ummmm ... One method, archaic, is to use Switch Clustering.
Very old and I don't see any benefit other than to save IP address to the management VLAN.
Hi Leo,
Horizontal Stacking is working succesfully on Catalyst 2960X with 10G uplinks. IOS 15.2(5)E2
SW12-C2960X-48P-HSTACK-TUL#sh switch hstack-ports
 Horizontal stack port status :
 Te Ports   Stack Port   Operational Status   Next Reload Status   Media Type
 Te1/0/1      NA           N/W Port           N/W Port            Fiber
 Te1/0/2      2            Stack Port         Stack Port          Fiber
 Te2/0/1      1            Stack Port         Stack Port          Fiber
 Te2/0/2      2            Stack Port         Stack Port          Fiber
 Te3/0/1      1            Stack Port         Stack Port          Fiber
 Te3/0/2      2            Stack Port         Stack Port          Fiber
You achieved this by using regular uplink ports from switch? Or are you using the new FlexStack-Extended modules (fiber or hybrid)?
From what I have read, it seems that we can use regular uplink ports for stacking (without the need to buy an stack module) but I have no switches to test this.
Joao Carvalho
Yes, using only regular uplink ports.
