Cisco 4500 Upgrade
NETAD
Level 4
Level 4
Hello, I'm planning an upgrade and need to know if it can be done without downtime. We have 2 4500's in a VSS running 03.07.01.E and wanting to go to 3.11.1.
Can someone tell me the procedure and if I need to follow a certain path.
thanks
8 Replies 8
Reza Sharifi
You can go directly from 03.07.01.E to 3.11.1. but you need a maintenance window, as you would need to reboot both chassis at the same time. The boot time is about 15 minutes.
Can you please send me the procedure.
and documentation on where it says we can jump straight to the 3.11.1. Thanks
Have a look at this post
https://community.cisco.com/t5/switching/4500x-upgrade-path-from-3-6-7-to-3-11-recommendation/td-p/4005179
This is for 4500x but you should be able to do the same with 4500 VSS.
Leo Laohoo
Read the Release Notes very, very carefully.
To upgrade a VSS pair to 3.11.X, the ROMMON must be upgraded.
In regards to procedures, have a look at THIS.
pkumari4
Hello Netad,
I can see that you are looking to perform the upgrade on 4500 VSS with minimum downtime indeed 0 downtimes. You can use the ISSU method to achieve the same. I am sending you the compatibility matrix as well the procedure to perform an upgrade on the 4500 VSS using the ISSU method,.
The ISSU code compatibility matrix:
file:///Users/pkumari4/Downloads/Catalyst%204500_4900%20series%20ISSU%20compatibility%20matrix.pdf
The ISSU upgrade guide:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/vss.html#wp1322727
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-8-0E/15-24E/configuration/guide/xe-380-configuration/issu_XE.html
Priyanka
This is not going to help.
Deepak Kumar
HI,
I think @Leo Laohoo has shared a good guide and I am also using the same. I tried with ISSU but only 30% - 40% success rate and will take more time.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
