Cisco 4503 crashes when one power supply loses power
lbjwusatx
I have a Cisco 4503 which will without fail crash when power is lost to one power supply.
All of the LEDs will illuminate on the switch in red/alarm state and it will stop passing traffic.
The failure scenarios are as follows:
- Run on any one power supply - OK
- Run on any one power supply and then power on second power supply while running - Crash
- Run on both power supplies and lose power to any second power supply while running - Crash
Obviously, this is not a very good situation as there is no power redundancy!
I haven't been able to confirm any console messages when this occurs.
The device is running  IOS 15.0(2)SG6.
#sh module
Chassis Type : WS-C4503
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     2  Supervisor IV 1000BaseX (GBIC)         WS-X4515
2     6  SFP, 10/100/1000BaseT (RJ45)V, Cisco/I WS-X4506-GB-T
3    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45
There is sufficient capacity to run on one power supply:
Power                                             Fan      Inline
Supply  Model No          Type       Status       Sensor   Status
PS1     PWR-C45-1000AC    AC 1000W   good         good     n.a.
PS2     PWR-C45-1000AC    AC 1000W   good         good     n.a.
Power supplies needed by system    : 1
Power supplies currently available : 2
Power Summary                      Maximum
(in Watts)              Used     Available
System Power (12V)        230        1050
Inline Power (-50V)         0           0
Backplane Power (3.3V)      0          40
Total                     230        1090
The power supplies are configured in redundancy mode:
#sh run | I power
power redundancy-mode redundant
Any ideas? Known bugs?
glen.grant
  Sounds like you have found a bug , contact the TAC or find a late release 12.2 release which are more stable than the 15 releases.
