04-16-2014 06:20 AM - edited 03-07-2019 07:07 PM
Guys,
Please assist. We got a new replacement for existing 4500 SW to 4506E. I have just noticed that the confreg is 0x2101 instead of the usual 0x2102. After reading documentation, i understood that the two confregs are basically one and the same thing.
However, one interesting thing that I have noted is that when i execute the show run command, I do not get an output and the session just handgs there. Need to disconnect then connect again. All other commands even startup are ok. Just this one.
This command is there boot system flash bootflash:cat4500e-universalk9.SPA.03.05.00.E.152-1.E.bin
econdly, I have noted that vty sessions are also not getting expired despite the fact that the timer is set to disconnect after few minutes.
line con 0
exec-timeout 15 0
privilege level 15
login authentication local_auth
stopbits 1
line vty 0 4
session-timeout 3
exec-timeout 3 0
transport input telnet ssh
transport output telnet ssh
line vty 5 15
session-timeout 3
exec-timeout 3 0
Even the disconnect and clear commands do not help.
1) Is it the confreg that is causing these issues?
2) Should I change to the 2102 confreg or leave as is?
Solved! Go to Solution.
04-16-2014 04:06 PM
Config-registry value of 0x2101, particularly the last octet of "1" means that the supervisor card will ignore the boot variable string and boot the FIRST IMAGE found in the flash.
On a Cat 2K and 3K, if you change the last octet to "2", it will look for a boot variable string if not fall back to the first image found in the flash. Unfortunately, 4500 and 6500 supervisor cards do not like it when you've got 0x2102 config registry and you do NOT have a valid (or correct) boot variable string. If you have 0x2102 and you either have no boot variable string or your boot variable string is incorrect (like wrong filename, for instance), your switch will boot into ROMmon.
Supervisor cards are shipped with 0x2101 config-registry by default. It is up to your discretion to change it. It is also a good way to find out whether or not you're network engineers know what they are doing or not.
That's the difference between the two.
04-16-2014 04:06 PM
04-16-2014 04:06 PM
This is what an it looks like when you boot with a 0x2102 config registry looks like:
config-register = 0x2102 Autobooting using BOOT variable specified file..... Current BOOT file is --- bootflash:IOS_filename.bin Loading image !!!!!!!!!!!!!!!!!!!!!!
And this is what it looks like when you use 0x2101 config-registry
config-register = 0x2101 Autobooting using the first file from bootflash..... Loading image !!!!!!!!!!!!
Do you see the difference?
09-22-2014 01:22 AM
Thank you Leo for pointing out the difference.
We also found that the IOS had a bug and that was why I could not perform the show run. This is what we were and still are using cat4500e-universalk9.SPA.03.05.00.E.152-1.E.bin.
Rebooting the switch helps for some time but we do plan on upgrading IOS to completely solve the issue.
