Bookmark
Subscribe
1071
Cisco 4510 loop booting
olegbarzasekov
Dear community,
I have Cisco 4510. After global power error this device try to boot:
Verifying FPGA (P) Signature ....................... PASSED
Verifying ROMMON (P) Signature ......... PASSED
* Rom Monitor *
* Copyright (c) 2012-2014 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor (P) Version 15.1(1r)SG4
Compiled Thu 05-Jun-14 11:15 [RLS]
System : WS-X45-SUP8-E Slot [6]
Chassis : WS-C4510R*E
Revision : CPU 2.1 BOARD 4.0 FPGA 3.1C4A.9621
Memory : 4096 MB
Date : Tue Jul 02 05:35:29 2019
config-register = 0x2212
Autobooting using BOOT variable specified file.....
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method, type 'confreg' command.
* Rom Monitor *
Memory : 4096 MB
Date : Tue Jul 02 05:35:40 2019
This is loop booting. switch didn't responsible to Ctrl Break combination and still try to boot in loop.
How I can get ROMMON menu? No record "press Ctrl C"
marce1000
 - Try pressing Ctrl-C after the Autobooting... , line.  Your config-register setting is also weird. Check this document :
  https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html
M.
Leo Laohoo
This is why it's looping.
Change it to 0x2102.
olegbarzasekov
I can't break loop.
I tried to remove Smart Modular (memory 32) and get ROMMON. With Smart Modular I can't entry to rommon.
I guess some thing wrong with memory, isn't it?
Is it possible to fix memory? Or buy it on eBay?
If Smart Modular is broken, Can I use usb stick or SD cart instead of flash?
