Redunancy with Nexus to HP Procurve
JakubMalik1782
Dear all,
In our data center are two HP ProCurve 6120XG Blade Switches connected to two Nexus 5000 switches.
Hp procurve switch no.1 is connected to Nexus switch no.1 with one link (blue)
HP procurve switch no.2 is connected to Nexus switch no.2 with one link (blue)
Current connection is without red links, only with blue links.
I'd like to add another two links (red) for 100% redunancy.
What is the best way for best redunancy connection and what do I need to configure on the switches ?
I guess it would be possible with vPC .... ??
Sorry for my english ...
Thank you for your reply.
9 Replies 9
Hi @JakubMalik1782,
Yes, you can make use of the vPC feature on your Cisco Nexus 5000. The advantage of vPC is that you can utilize all your uplinks (100% bandwidth capacity) instead of having Spanning-Tree (STP) blocking your redundant links (50% bandwidth capacity).
Here a good whitepaper that can start helping you with the configuration Virtual PortChannel Quick Configuration Guide.
Once you have configured the following on both or your Nexus 5000:
  1. enable the vPC feature
  2. configured a vPC domain
  3. configured the vPC keepalive link
  4. configured the vPC peer-link
You can enable LACP on your HP Switches and in your bundle of vPC lins on your Nexus 5000s.
I hope this helps.
Hello
Are the nxos vCP peered together - meaning are they multi-chassis ether-channeled together - If so you can create vPC members of the hp switches so resiliency is introduced for them just like you have shown in your topology.
Kind Regards
Paul
balaji.bandi
As long as both the nexus configured in vPC domain (in the picture not shown as connected) - that is the best practice, then add the red link as per your requirement for the resilience connection for high availability.
BB
Yes, nexus switches are configured in vPC domain.
Here is config:
N5K-1# sh running-config interface po1
!Command: show running-config interface port-channel1
!Time: Wed Jul  3 13:50:11 2019
version 7.1(0)N1(1b)
  description vPC peer-link
  switchport mode trunk
  spanning-tree port type network
  vpc peer-link
N5K-1# sh running-config interface eth1/47
!Command: show running-config interface Ethernet1/47
!Time: Wed Jul  3 13:50:56 2019
  description vPC peer-link #1
  channel-group 1 mode active
N5K-1# sh running-config interface eth1/48
!Command: show running-config interface Ethernet1/48
!Time: Wed Jul  3 13:50:59 2019
  description vPC peer-link #2
So, how should be configured interfaces with red and blue links ? Same as po1 or eth1/48 ?
on Cisco side use a vpc PO on HP side use standard port-channel
example Cisco side config ,e1/1 on both switches , po4 needs to be on both sides too so iyt forms the VPC between the switches
interface port-channel4
description xxxxxxxxxxxxxxxxxxxxxxxxxxx
no lacp suspend-individual
switchport trunk allowed vlan 2,10-11,17-18,20,28,31,33-34,36-39,48,50,64-65,70,72,74,76,78,80,90-96,102-103,105,107,226,400,1226,2224,2512,3020,3025-3028
logging event port link-status
logging event port trunk-status
speed 10000
vpc 4
interface Ethernet1/1
channel-group 4 mode active
description
sh vpc 4
vPC status
id Port Status Consistency Reason Active vlans
4 Po4 up success success 2,10-11,17-
18,20,28,31
,33-34,36-3
9,48,50,64-
65,70,72....
Hello Mark,
Is this config OK ?
description HP_c7000_Blade vPC peer-link #2
switchport trunk allowed vlan 1,20,43-44,61,80,100,127,413-415,419,503,505-506
speed 10000
vpc 4
interface Ethernet1/37
description HP_c7000_Blade_SW1
interface Ethernet1/38
description HP_c7000_Blade_SW2
yes looks good , this would be all ports , each server would have a link back to each 5k under its own VPC
identical config on both sides , best to match the ports , so 37 on each side for serverA and port 38 on each side for serverB
5KA
description HP_c7000_Blade vPC 4
speed 10000
vpc 4
description HP_c7000_Blade_SW1 vpc4
interface port-channel5
description HP_c7000_Blade vPC 5
speed 10000
vpc 5
description HP_c7000_Blade_SW2 VPC5
channel-group 5 mode active
5KB
speed 10000
vpc 4
speed 10000
vpc 5
On HP Procurve switch should be turn on feauture LACP ?
Yes you will need LACP on the HP side too , it just will not support the VPC syntax
