Cisco 4900 ping issue
Tejas Kunte
i have a Cisco 4900 and following is the config
my problem is ..from the 4900 i can ping 10.11.20.1 which is the interface of my firewall, but i cant ping my management server that is across a VPN that terminates on the 10.11.20.1 fw i have verified there are no ACLs blocking traffic.
any ideas ?
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.05.02 09:34:47 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 2810 bytes
version 15.0
no service pad
service compress-config
hostname ecw12sw006
boot-start-marker
boot system flash bootflash:cat4500e-ipbase-mz.150-2.SG1.bin
boot-end-marker
enable secret 5 $1$cn/7$WRGp36aCFuNrar7CYkXGT.
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
switchport
switchport mode trunk
interface Port-channel2
switchport
interface FastEthernet1
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface TenGigabitEthernet1/3
interface TenGigabitEthernet1/4
interface TenGigabitEthernet1/5
interface TenGigabitEthernet1/6
interface TenGigabitEthernet1/7
interface TenGigabitEthernet1/8
interface GigabitEthernet2/1
channel-group 2 mode active
spanning-tree portfast trunk
interface GigabitEthernet2/2
interface GigabitEthernet2/3
interface GigabitEthernet2/4
interface GigabitEthernet2/5
switchport access vlan 3
interface GigabitEthernet2/6
interface GigabitEthernet2/7
interface GigabitEthernet2/8
interface GigabitEthernet2/9
interface GigabitEthernet2/10
interface GigabitEthernet2/11
interface GigabitEthernet2/12
interface GigabitEthernet2/13
interface GigabitEthernet2/14
interface GigabitEthernet2/15
interface GigabitEthernet2/16
interface GigabitEthernet2/17
channel-group 1 mode active
interface GigabitEthernet2/18
interface GigabitEthernet2/19
interface GigabitEthernet2/20
interface Vlan1
no ip address
interface Vlan3
ip address 10.11.20.45 255.255.255.0
ip default-gateway 10.11.20.1
ip http server
end
ecw12sw006#
hello
can you ping it from the fw? icmp is allowed?
if so then it sounds like a the server may not know how where to return traffic - check its got a route baxk towards this 4900
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
