Cisco 4900 switch unexpected reboot
tedauction
Hello, I entered the command 'aaa new-model' on this switch and it unexpectedly, suddenly rebooted. Is this a confirmed bug ?
4900A - firmware '12.2(53)SG10'
Thank you for any information.
5 Replies 5
balaji.bandi
This require more debugging, if you have contact better to open cisco TAC case.
or provide more console logs.
BB
BB
Leo Laohoo
Post the complete output to the following commands:
1. sh version; and
2. dir
Hello, as requested here is the output of 'sh ver' and 'dir':
TEAKL-4900A#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(53)SG10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 13-Dec-13 12:46 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x1258F7B4
ROM: 12.2(44r)SG10
Darkside Revision 0, Jawa Revision 11, Tatooine Revision 140, Forerunner Revision 1.78
TEAKL-4900A uptime is 5 days, 23 hours, 35 minutes
System restarted at 10:25:06 NZST Tue Jun 26 2018
System image file is "bootflash:cat4500e-ipbasek9-mz.122-53.SG10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4900M (MPC8548) processor (revision 2) with 1048576K bytes of memory.
Processor board ID JAE17480D1L
MPC8548 CPU at 1.33GHz, Cisco Catalyst 4900M
Last reset from PowerUp
5 Virtual Ethernet interfaces
20 Gigabit Ethernet interfaces
12 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2142
TEAKL-4900A#
TEAKL-4900A#
TEAKL-4900A#dir
Directory of bootflash:/
6 -rw- 24614681 Nov 20 2015 08:28:46 +13:00 cat4500e-ipbasek9-mz.122-53.SG10.bin
122007552 bytes total (89931776 bytes free)
Can you please post the complete output to the command "sh crashlog"?
thank you for your help. I have just confirmed this is a known bug: Bug CSCun08435
