Cisco 6500 boot problems
Hi ,
We have WS-6509-E and I have noticed this it loaded wrong image. below is results of show version:
IOS (tm) s72033_rp Software (s72033_rp-JK9O3SV-M), Version 12.2(17d)SXB11, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 15-Nov-05 15:33 by pwade
Image text-base: 0x40020FBC, data-base: 0x422F8000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-JK9O3SV-M), Version 12.2(17d)SXB11, RELEASE SOFTWARE (fc1)
6500 uptime is 1 year, 3 weeks, 6 days, 2 hours, 59 minutes
Time since DR-6500 switched to active is 1 year, 3 weeks, 6 days, 2 hours, 59 minutes
System returned to ROM by error - a Software forced crash, PC 0x428A667C at 13:28:52 GMT+2 Mon Oct 1 2012 (SP by power-on)
System restarted at 13:37:54 GMT+2 Mon Oct 1 2012
System image file is "sup-bootflash:s72033-jk9o3sv-mz.122-17d.SXB11.bin"
But we have corrected image and boot configuration:
boot system flash s72033-ipservicesk9-mz.122-33.SXJ2.bin
Lastly what it latest ios image of 6509?
Johnn
5 Replies 5
Sanjay Shaw
Level 4
Level 4
Please paste the show modules output here.
Sent from Cisco Technical Support Android App
Hi Sanjay,
Thanks.
I think I found what was the problem, the boot system command is incorrect:
boot system flash s72033-ipservicesk9-mz.122-33.SXJ2.bin,
it suppose to be boot system flash disk0:s72033-ipservicesk9-mz.122-33.SXJ2.bin.
Will change it and reload.
Tinya Cheng
What does a "show bootvar" say? You may have configured it for the correct IOS image, but preceding configured boot statements take precedence. You may have to remove any previous boot statements from your current config.
Have you checked for the presence of the image in the flash to make sure it is actually there? If it is not there, it will boot from the first IOS image the supervisor finds.
Have you verified that your config-register is set for 0x2102? This should be see at the end of the "show version" output.
The latest IOS image does not go by chassis, but rather by supervisors. To see the latest IOS image for your supervisor, you will have to search for downloads on cisco.com under your supervisor model. Keep in mind that there are several Sup720 models.
show bootvar:
BOOT variable = s72033-ipservicesk9-mz.122-33.SXJ2.bin,1
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby is not present.
Standby not ready to show bootvar
The image is presence on disk0.
config-register is set to 0x2102
You would need to set your boot statement as follows:
boot system disk0:s72033-ipservicesk9-mz.122-33.SXJ2.bin
