Cisco 6509 High Cpu
CSCO11177789
Hi;
When we check the cpu usage of the switch ,we take this output.
Isn't it high ? What could we do to reduce ?
We have about seventy vlan with HSRP, eighty edge switches with fiber. We dont use BGP protocol, only a few static routes.
Thanks.
Ios ver : Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(33)SXH3, RELEASE SOFTWARE (fc1)
Lucien Avramov
Level 10
Level 10
Your CPU output seems completely fine.
I suggest the use of the command show proc cpu history, that will show you when spikes happen.
It's OK to have high CPU on a a router, it depends what it's doing.
20% of CPU is completely fine, you should not worry about it.
Thanks for your reply. We feel better now.
