gratuitous-arps
jabercromby
Community Member
It appears (to me at least) that the documentation (Command References) and command lookup tool provide elusive/and almost contradict each other on what the default behavior is) for:
no ip gratuitous-arps
ip gratuitous-arps
On top of that it appears that Cisco does not support these
commands on certain IOS based Catalysts.
I thought (most likely incorrect) that 'ip gratuitous-arps' were enabled by default through 12.2?
12.3 on - no ip gratuitous-arps was the default
end of story.
Can someone please provide accurate information on this
or point me in the right direction?
Jim Abercromby
jabercromby
Community Member
Let me make sure I have this straight
For IOS/Router platforms = 'ip gratuitous arps'
disabled by default since 12.2
For Catalyst/Switch (MLS) etc. = 'ip arp inspection'
This is disabled by default too.
So if I am looking to see if a catalyst switch is
filtering/restricting gratuitous arps
'ip arp inspection filter vlan' commands
filtering specific vlans would have to be configured.
YES or NO?
1. NO: For IOS/ROUTERS, by default, if no command is entered:
Gratuitous ARP messages are NOT sent out when the client receives the address from the local address pool.
2. YES for Catalyst, Dynamic Arp Inspection, not enabled by default
