Cisco 6509 with 10G Module
anis_cisco
We have Cisco 6509 Core Switch with following details & we need to install WS-X6716-10T-3C module in int.
Can some body advise which slot number i should use in 6509 ?
Do i need to upgrade supervisor engine IOS for this ?
Is it hot swapable module & can i install this module in production ?
 6509_CORE#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI6, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 28-Mar-11 12:09 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
6509_CORE uptime is 2 years, 30 weeks, 1 day, 3 hours, 13 minutes
Uptime for this control processor is 2 years, 30 weeks, 1 day, 1 hour, 44 minutes
Time since AUB_CORE switched to active is 2 years, 30 weeks, 1 day, 1 hour, 44 minutes
System returned to ROM by  power cycle at 11:55:23 UTC Wed Apr 27 2011 (SP by power-on)
System restarted at 11:16:22 AST Sun Jun 26 2011
System image file is "sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI6.bin"
Last reload reason: Reload Command
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
Processor board ID SMC1426001S
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
4294967295 Ethernet interfaces
33 Virtual Ethernet interfaces
150 Gigabit Ethernet interfaces
100 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
6509_CORE#sh module
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1430P2QU
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1429N6XB
  3   16  CEF720 16 port 10GE                    WS-X6716-10GE      SAL1430NYUE
  4   16  CEF720 16 port 10GE                    WS-X6716-10GE      SAL1430NX5A
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1430NUJE
  7   16  CEF720 16 port 10GE                    WS-X6716-10GE      SAL1645RJTF
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  d0d0.fd62.d9e0 to d0d0.fd62.d9f7   4.4   12.2(18r)S1  12.2(33)SXI6 Ok
  2  c84c.75b8.596c to c84c.75b8.599b   3.4   12.2(18r)S1  12.2(33)SXI6 Ok
  3  001f.6cac.11d0 to 001f.6cac.11df   1.0   12.2(18r)S1  12.2(33)SXI6 Ok
  4  5475.d06e.0988 to 5475.d06e.0997   1.0   12.2(18r)S1  12.2(33)SXI6 Ok
  5  001e.4a7f.3068 to 001e.4a7f.306f   3.2   8.5(4)       12.2(33)SXI6 Ok
  7  fc99.4736.2d80 to fc99.4736.2d8f   1.1   12.2(18r)S1  12.2(33)SXI6 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Distributed Forwarding Card WS-F6700-DFC3C     SAL1430P282  1.4    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1430NRAS  4.1    Ok
  3  Distributed Forwarding Card WS-F6700-DFC3C     SAL1430P26L  1.4    Ok
  4  Distributed Forwarding Card WS-F6700-DFC3C     SAL1430NZRM  1.4    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1429N6B7  1.1    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1430NN3R  5.0    Ok
  7  Distributed Forwarding Card WS-F6700-DFC3C     SAL1644RAZF  1.5    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Pass
  7  Pass
11 Replies 11
Leo Laohoo
WS-X6716-10T-3C should be compatible with your current setup.
Thank for reply Leo,
Can you advise which slot number i should use in 6509 ?
You can insert this line card during production hours,  however, make sure you have proper change control in case something untowards happen.
You can insert this line card into any slot except slots 5 and 6.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
My understanding, either slot 5 or 6 would be fine too as long it's empty and you don't plan to populate both with a sup.
Although 6500 line cards support OIR, on rare occasion a problem is created.  Recommend doing during non-production time or during scheduled maintenance time.
Why does Leo say you cannot install in slots 5 or 6. I have heard this before but cant find any reason other than thats where the Sups go
slots 5 and 6 are reserved for the sups. Supervisors have to go into these slots due to the crossbar fabric on the sups.
in a single sup chassis, the sup must be in slot 5. However, linecards will work, at least in my experience, in slot 6. I believe it's a bad practice and should only be done if absolutely necessary, but does work. What you will notice, if you do this, is that the power allocation is always done for a 2nd sup, so you won't actually see the power draw of the card.......that being said if the draw of your card is greater than the sup, I don't think it will work, but that's just a guess.
In my environment, we have a couple instances where we are using an old 6516 card in slot 6, and that doesn't draw more power than the sup3b, so it works for us.
chris
Thanks. I completely overlooked that. I thought it was just slot 5 you couldnt use.  Fortunately slot 2 is available
Because it won't fit.  With a torch/flashlight/pen light, look at the pins at the slots 5 and 6.  Compare the pins of the rest of the slots.  They are different.  This is because, like what Chris said, slots 5 and 6 are used for Supervisor cards only.
you don't mention what type of power supplies you have, just might want to double check to make sure you have enough power for the new card. - chris
I can check the power details by tomorrow & can share with you.
Mean While can you tell me how much Power is required for this module ?
Hello cmarva,
I got power requirement from core switch:
6509_CORE#show power
system power redundancy mode = redundant
system power total =     3795.12 Watts (90.36 Amps @ 42V)
system power used =      2748.06 Watts (65.43 Amps @ 42V)
system power available = 1047.06 Watts (24.93 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
2    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6509-E-FAN      210.00  5.00  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6724-SFP        162.96  3.88   162.96  3.88  on    on
2    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
3    WS-X6716-10GE       457.80 10.90   457.80 10.90  on    on
4    WS-X6716-10GE       457.80 10.90   457.80 10.90  on    on
5    VS-S720-10G         338.10  8.05   338.10  8.05  on    on
6    (Redundant Sup)       -     -      338.10  8.05  -     -
7    WS-X6716-10GE       457.80 10.90   457.80 10.90  on    on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   10920.00 Watts (260.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used =              2748.06 Watts (65.43 Amps @ 42V)
system auxiliary power used =            0 Watt
As per Cisco document i require this power WS-X6716-10T-3C: 509.3W (12.1A @ 42V) & from output available power is system power available = 1047.06 Watts (24.93 Amps @ 42V)
Looks like im good to go. Can you verify please ?
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/product_data_sheet09186a00801dce34.html
