Cisco 831 CEF Problem
machiavelli
I have problem to enable CEF on my Cisco 831 router (2Eth+4FastEth ports). As I can conclude, default IOS on it (12.3(2)XE3) supports CEF, but I have problem with enabling. When I type "IP CEF" in config mode, router stop responding for a few seconds, and after that in "sh ip cef" output I get "%CEF not running". I would be grateful for the answer.
wochanda
Level 8
Level 8
You're running a pretty obscure version of IOS. Upgrade to either a 12.3T or 12.4 mainline release and see if you have better luck.
wochanda
Level 8
Level 8
I've replaced my IOS with 12.4(8), and now I can enable CEF on my router. Thank You for the answer.
spremkumar
Level 11
Level 11
In addition to the other post you can make use of the below link to find out the exact ios code to have the required feature in your router..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
