Cisco 861W Interal AP not booting
Gerry Egan
Hi there,
I tried to upgrade the IOS on my internal AP and now I am in a reboot cycle. I have tried to manually boot the old and new IOS images from the rommon but neither are working. here is the output I am getting:
ap: dir flash:
Directory of flash:/
2    -rwx  6563840   <date>               ap801-k9w7-tar.124-21a.JY.tar
4    drwx  256       <date>               ap801-k9w7-mx.124-21a.JA1
152  -rwx  548       <date>               env_vars
153  -rwx  2775      <date>               cpconfig-ap801.cfg
154  -rwx  2775      <date>               back_up.txt
155  -rwx  3763      <date>               config.txt
156  -rwx  168       <date>               r0.rcore
157  -rwx  3775      <date>               backup1234
158  -rwx  3553      <date>               private-config
159  drwx  256       <date>               ap801-k9w7-mx.124-21a.JY
307  -rwx  1048      <date>               private-multiple-fs
11915776 bytes available (19566080 bytes used)
ap:
ap: dir flash:/ap801-k9w7-mx.124-21a.JA1
Directory of flash:/ap801-k9w7-mx.124-21a.JA1/
5    drwx  64        <date>               html
149  -rwx  5714717   <date>               ap801-k9w7-mx.124-21a.JA1
150  -rwx  97896     <date>               8001.img
151  -rwx  287       <date>               info
ap: boot flash:/ap801-k9w7-mx.124-21a.JA1/ap801-k9w7-mx.124-21a.JA1
Loading "flash:/ap801-k9w7-mx.124-21a.JA1/ap801-k9w7-mx.124-21a.JA1"...############################################################################################################################################################################################################################
File "flash:/ap801-k9w7-mx.124-21a.JA1/ap801-k9w7-mx.124-21a.JA1" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, AP801 Software (AP801-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:59 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 293 files, 13 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31481856
flashfs[1]: Bytes used: 19566080
flashfs[1]: Bytes available: 11915776
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present A600 8000 A8020000 0 A8030000 30
IOS Bootloader - Starting system.
FLASH CHIP:  Spansion Mirrorbit (0001)
Xmodem file system is available.
Bringing up flash file system:
flashfs[0]: 293 files, 13 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31481856
flashfs[0]: Bytes used: 19566080
flashfs[0]: Bytes available: 11915776
flashfs[0]: flashfs fsck took 17 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: 64:00:f1:77:76:78
Ethernet Interface initialize.
Ethernet Interface initialize OK.
TFTP initialize OK.
Boot system image.
executing...
           cisco Systems, Inc.
flashfs[0]: flashfs fsck took 18 seconds.
TFTP initialize OK.
Boot system image.
Can you advise if I am doing something wrong or is there  a problem with my access point. The router is working fine.
Thanks!
Reza Sharifi
Not familiar with the APs, but do you have the correct image on your device?
I only see below image on CCO
Can you verify?
ap801-k9w7-tar.152-2.JA.tar
Reza Sharifi
Can you verify?
Gerry Egan
Thanks for your help. I have discovered that the unit is faulty.
thanks anyway.
