11-11-2017 06:40 PM - edited 03-08-2019 12:42 PM
Hi all,
We signed up for a NBN FTTN 100Mbps plan with iiNet with no contract.
Purchased a Cisco 867VAE-K9 outright from another supplier.
I've been trying to configure the router to work with NBN, but it doesn't seem to like it.
I used the sample Cisco NBN FTTN config from iiNet website. But, it still doesn't seem to work.
The WAN mode is set to DSL.
The VDSL interface goes UP, and 10 seconds later it goes down again.
When I use terminal monitor, I get this error:
*Nov 10 03:10:53.423: %CONTROLLER-5-UPDOWN: Controller VDSL 0, changed state to down
*Nov 10 03:10:54.423: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to down
*Nov 10 03:10:55.483: %LINK-3-UPDOWN: Interface Ethernet0, changed state to down
Can someone share me a working NBN FTTN config on a Cisco 867VAE-K9 router please? :)
Here is my config:
Test-GW#show run
Building configuration...
Current configuration : 4474 bytes
! Last configuration change at 02:22:42 UTC Sun Nov 12 2017
version 15.4
no service pad
hostname Test-GW
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa session-id common
wan mode dsl
no ip domain lookup
ip domain name yourdomain.com
ip name-server 203.0.178.191
ip name-server 203.215.29.191
ip cef
no ipv6 cef
flow record nbar-appmon
match ipv4 source address
match ipv4 destination address
match application name
collect interface output
collect counter bytes
collect counter packets
collect timestamp absolute first
collect timestamp absolute last
flow monitor application-mon
cache timeout active 60
record nbar-appmon
parameter-map type inspect global
max-incomplete low 18000
max-incomplete high 20000
crypto pki trustpoint TP-self-signed-2652789567
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2652789567
revocation-check none
rsakeypair TP-self-signed-2652789567
crypto pki certificate chain TP-self-signed-2652789567
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32363532 37383935 3637301E 170D3137 30393136 30383531
33315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36353237
38393536 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A6F5 F6CC3157 9D9164CC 18CB955F 6B955F51 7290A05B 09BABE16 24EC15FE
4D64CC0D A6DBCF0A 9B2A2010 612B9D52 074FDEE7 0F8C3C50 129D8B8D 91D0B4E7
71D878F9 CB4E82B5 90719742 0463B331 F09C46B3 1CAA42BE 5A67B2D2 6E93B22D
C76552AE 3D2990E5 ED083F45 FC65954A 44222F21 F0F8D6C6 F1E53248 F1C527E1
10310203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14168F26 53BCD882 CB05C9CF 972136FB A06E3893 A2301D06
03551D0E 04160414 168F2653 BCD882CB 05C9CF97 2136FBA0 6E3893A2 300D0609
2A864886 F70D0101 05050003 81810076 5CEE5457 919F638F 86B35B8C 17C63CDE
C9854D0B D3F3F5C9 003BAE32 57A1B20B 565DED20 44EE53FD D1FA7896 A2377ABB
C4628A75 D14CE226 FBBE9310 AF2F8902 9810FC72 E77E5675 228E2096 17153B76
7ED1BAB1 ACC6F36A 17B34A9E 3FEC58DD F5060BF2 4B539E64 B211C1EC E597B924
40461744 9962E35C EE3823EC 2278D3
quit
object-group service INTERNAL_UTM_SERVICE
object-group network local_cws_net
object-group network local_lan_subnets
any
object-group network vpn_remote_subnets
any
controller VDSL 0
operating mode vdsl2
no cdp run
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description *Exetel NBN*
pvc 8/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface Ethernet0
description *iiNet NBN*
ip address dhcp
ip mtu 1452
ip nat outside
ip virtual-reassembly in
no cdp enable
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
description $ETH_LAN$
ip address 192.168.30.248 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username <iinet username> password <iinet password>
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 100 interface Ethernet0 overload
ip route 0.0.0.0 0.0.0.0 Ethernet0
dialer-list 1 protocol ip permit
mac-address-table aging-time 10
access-list 100 permit ip 192.168.30.0 0.0.0.255 any
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
transport input ssh
scheduler allocate 60000 1000
end
Any help would be greatly appreciated.
11-12-2017 10:37 AM
there used to be a problem with certain IOS versions and NBN. Which version are you running ? Can you post the output of:
show version
show controller vdsl 0
Also, does it make a difference if you set the operating mode to 'auto' ?
