Cisco 887VA PPPOE connection on Fastethernet
Here is my network :
on Fastethernet 0 , my internal network with a dhcp pool 192.168.1.X on Vlan 1
I would like create a PPPOE connection based on fastehternet 3 and i would like to route FA0 to FA3 for internet request.
In attachment my tested configuration, but It doesn't work.
DO you have a exemple for this configuration?
Thank you
Diana Karolina Rojas
Here is a very good example of configuration: http://pingbin.com/2014/09/cisco-887va-m-vdsl2-pppoe-configuration/ and other: http://ganomi.com/index.php/10-cisco-887va-configuration
Read it and if you have a question you can write me for help.
---Do not forget to rate useful post.---
Hitesh Vinzoda
Level 4
Level 4
you need to add ip nat command under Dialer0
interface dialer0
ip nat outside
Hitesh
