Cisco 887VA trunk with more than two vlans
Mark Dayton
I'm having a problem with a 887va trunk port connected to a HP procurve switch.
VLAN1002 doesn't want to pass any traffic, can someone advise if I have missed anything?
Config 887va
interface FastEthernet0
switchport trunk allowed vlan 1,2,1002-1005
switchport mode trunk
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description SecondaryLine
ip address 10.11.151.2 255.255.255.0
ip accounting output-packets
ip virtual-reassembly in
ip tcp adjust-mss 1300
interface Vlan2
description GuestLAN
ip address 172.32.0.65 255.255.255.192
no autostate
interface Vlan1002
description CCTV
ip address 10.102.151.1 255.255.255.0
no autostate
HP Procurve 1810g
Trunk configured on port1
Untagged VLAN1
Tagged VLAN2
Tagged VLAN1002
Access port configured on port 7
Untagged VLAN2
Access port configured on port 8
Untagged VLAN1002
If I plug something into port 7 I get an IP from the DHCP pool configured in pool 1.
If I plug something into port 8 I get nothing, no IP.
DHCP pools as below
ip dhcp excluded-address 172.32.0.65
ip dhcp excluded-address 10.102.151.1
ip dhcp pool 1
network 172.32.0.64 255.255.255.192
dns-server 8.8.8.8 8.8.4.4
default-router 172.32.0.65
ip dhcp pool 2
network 10.102.151.0 255.255.255.0
default-router 10.102.151.1
Thanks in advance
The bit you missed is that Vlan 1002 is a special reserved VLAN.  You do not want to try and use this one - and I'm not at all surprised it didn't work :-)
http://etherealmind.com/cisco-ios-vlan-1002-reserved-1005-purpose-function/
Mark Dayton
Got this sorted, took all day but I found that vlan 1002 was inactive even though it was assigned to a local fa port.
I have since changed this to vlan10 and it works like a charm.
I have highlighted the parts that I found a problem with below.
router#sh int switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: 1-3,10,213,250,300
Protected: false
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Switchport: Enabled
Administrative Mode: static access
Operational Mode: down
Access Mode VLAN: 10 (VLAN0010)
Trunking VLANs Active: none
Protected: false
Voice VLAN: none
Switchport: Enabled
Access Mode VLAN: 2 (VLAN0002)
Protected: false
Voice VLAN: none
Switchport: Enabled
Access Mode VLAN: 1 (default)
Protected: false
Voice VLAN: none
router#sh int trunk
Port Mode Encapsulation Status Native vlan
Fa0 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa0 1-4094
Port Vlans allowed and active in management domain
Fa0 1-3,10,213,250,300
Port Vlans in spanning tree forwarding state and not pruned
Ah yes thanks for this, didn't realise.
