SG500-28P - Keeps losing Static IP? Reverts to DHCP?
richard klein
I have a SG500-28P switch & have had it for a few years.  I am noticing that periodically it loses its static IP, password, etc.  Just reverts to a factory setting.  i have reset the unit 5 times over the years.  I am using POE (about 20% usage).
I dont access the switch often as my network works fine but it is annoying to reset this once in a while.
Any ideas on whats wrong?
Native Stacking
L2 Mode
SG500-28P 28-Port Gigabit PoE Stackable Managed Switch
Edit
Edit
switch43e36b Edit
1.3.6.1.4.1.9.6.1.81.28.2
43 day(s), 12 hr(s), 43 min(s) and 38 sec(s)
c4:72:95:43:e3:6b
Disabled
Software Information
1.4.1.3
f73388df555545d4ac56b89a208493c9
1.4.1.3
1.4.0.02
accbdaec117726d0e5149babc5b2a0b0
en-US
1.4.1.3
N/A
Edit
Enabled
Enabled
Disabled
Disabled
Disabled
Detail
180
20
Port Limit
Mark Malone
You could have triggered a bug in the firmware there are 2 more releases ahead of the one your on , I would try them see if it stabilizes it , its unlikely anything you configured on those switches that would randomly cause that
https://software.cisco.com/download/release.html?mdfid=284852375&flowid=46846&softwareid=282463181&release=1.4.5.02&relind=AVAILABLE&rellifecycle=&reltype=latest
