Cisco 891-W Wireless Issues
MrDvD
Hello Cisco,
hopefully someone with more expertise with the Cisco 891-W router can help me figure out my configuration issues?  Right now I have the wired part of the 891-W working fine with my cable modem on VLAN1.  But it's another story with my VLAN4 (wireless side).  I've been working on this all week and am hoping some fresh eyes can catch what's wrong with my config.   Currently, my laptop will see the SSID of the Wi-Fi (891W-WiFi) but when I try to connect I get an 169.254.180.251 IP?   Not sure if it's the DHCP or some kind of bridging with the AP module with the correct VLAN settings with my configuration?  I'll post my config below for both the router and AP.  Thank you to anyone that can give me some insight!
I've attached the configs just in case this post was too messy to read with all the configurations.
891W_Router#sh run
Building configuration...
Current configuration : 4826 bytes
! Last configuration change at 21:49:24 UTC Fri Apr 24 2015
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
hostname 891W_Router
boot-start-marker
boot config usbflash0:CVO-BOOT.CFG
boot-end-marker
no logging on
enable secret 5 $1$3JJJ$6wL98gGvGJQ0ot1xChXJt1
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
crypto pki trustpoint TP-self-signed-1853469223
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1853469223
 revocation-check none
ip source-route
ip dhcp excluded-address 192.168.99.1
ip dhcp excluded-address 192.168.100.1
ip dhcp pool Vlan4
   network 192.168.100.0 255.255.255.0
   default-router 192.168.100.1
   dns-server 8.8.8.8
ip dhcp pool Vlan1
   network 192.168.99.0 255.255.255.0
   default-router 192.168.99.1
   dns-server 192.168.0.1
ip cef
no ip domain lookup
ip name-server 209.18.47.61
ip name-server 209.18.47.62
ip inspect log drop-pkt
no ipv6 cef
parameter-map type inspect global
 log dropped-packets enable
license udi pid CISCO891W-AGN-A-K9 sn FTX15130301
username dvd privilege 15 secret 5 $1$qHnY$pMyIf18Av.AS2ne0cxXle/
username cisco password 7 01100F175804
bridge irb
interface FastEthernet0
 switchport mode trunk
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0
 description WAN
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip address 10.10.10.10 255.255.255.255
 arp timeout 0
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 switchport trunk native vlan 4
interface Vlan1
 description Internal LAN
 ip address 192.168.99.1 255.255.255.0
 ip nat inside
interface Vlan4
 description Wi-Fi Users
 ip address 192.168.100.1 255.255.255.0
 ip nat inside
interface Async1
 no ip address
 encapsulation slip
interface GMPLS8
 no ip address
 no fair-queue
 no keepalive
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0 overload
ip nat inside source list 2 interface Wlan-GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 dhcp
logging esm config
access-list 1 permit 192.168.99.0 0.0.0.255
access-list 2 permit 192.168.100.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
 exec-timeout 0 0
 password 7 020D0A5409040A2243401A160912
 logging synchronous
 login
line 1
 modem InOut
 stopbits 1
 speed 115200
 flowcontrol hardware
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin udptn ssh
line aux 0
line vty 0 4
 password 7 130E191D090E013C3F3D
 login
 transport input all
end
AP Configuration:
891W_Router#
891W_Router#service-module wlan-ap 0 session
Trying 10.10.10.10, 2002 ... Open
Connecting to AP console, enter Ctrl-^ followed by x,
then "disconnect" to return to router prompt
ap#sh run
Current configuration : 1976 bytes
version 12.4
no service pad
hostname ap
enable secret 5 $1$bW7h$C2mBp2TNgGbgkgj2fQHDa.
no aaa new-model
dot11 syslog
dot11 ssid 891W-WIFi
dot11 ssid 891W-WiFi
   vlan 4
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 0 cisco891
username cisco privilege 15 secret 5 $1$yIzh$7/j0K1xcYbT99mP4hX3ZU/
username dvd password 0 kmob
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 4 mode ciphers aes-ccm tkip
 ssid 891W-WiFi
 antenna gain 0
 station-role root
interface Dot11Radio0.4
 encapsulation dot1Q 4 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 antenna gain 0
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
 description the embedded AP GigabitEthernet 0 is an internal interface
connecting AP with the host router
 no ip address
 no ip route-cache
interface GigabitEthernet0.4
 no ip route-cache
 bridge-group 1
interface BVI1
 ip address dhcp
 no ip route-cache
ip default-gateway 192.168.100.1
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
 privilege level 15
 login local
line vty 0 4
 login local
cns dhcp
end
10 Replies 10
m.george
On the router:
interface wlan-ap0
 ip unnumbered Vlan1
On the access point:
dot11 vlan-name <vlan> vlan 4
! replace <vlan> with your VLAN  name as used on router for consistency
Remove bridge group 1 from .4 subinterfaces and restore to main interface.
The interfaces will look like this when finished:
 no ip address
 no ip route-cache
 ssid 891W-WiFi
 antenna gain 0
 station-role root
 bridge-group 1
 no ip route-cache
 bridge-group 4
 bridge-group 4 subscriber-loop-control
 bridge-group 4 block-unknown-source
 no bridge-group 4 source-learning
 no bridge-group 4 unicast-flooding
 bridge-group 4 spanning-disabled
 no ip address
 no ip route-cache
 ssid 891W-WiFi
 antenna gain 0
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
interface Dot11Radio1.4
 no ip route-cache
 bridge-group 4
 no ip address
 no ip route-cache
 bridge-group 1
 no ip route-cache
 bridge-group 4
Then you can give your BVI1 interface a static IP address in VLAN 1 and restrict the VTY lines to only allow access from VLAN 1 not VLAN 4 for security.
The result is you have the SSID tied to VLAN 4 on both wireless interfaces and the virtual interface back to the router. The management address for the access point is on the wired subnet and you can restrict management of your network to this subnet, preventing wireless hosts from managing the network - not a good look.
Once you have tidied this up see if that has solved your problem please. I hope this makes sense!
What george is suggesting is indeed a better solution to create subinterfaces for the MGMT VLAN 1 and VLAN 4 user traffic on the AP.
The trunk from the router will then trunk vlan 1 and 4.
Cant really find anything else that is wrong with config other then you might want to remove the default cisco username.
And also the level 7 encryption is very weak so you might wanna change youre passwords from atleast the console.
Furthermore always watch out if there arent any username's passwords or snmp strings in cleartext when posting a config online.
I know this thread is 4 years old, but I have the same issue with my 891W, I followed the advice given here, but I cant get an DHCP IP address when connecting to my AP. If i set a static IP I still cant get out to the internet , the router part is fine
 the configs are attached
attached the (what I think should be) working configuration. Changes and important parts are marked in bold:
version 15.1
no service pad
boot-start-marker
boot-end-marker
no logging on
enable secret 5 1100105
no aaa new-model
ip source-route
ip dhcp pool Vlan4
dns-server 8.8.8.8
ip dhcp pool Vlan1
ip cef
no ip domain lookup
no ipv6 cef
bridge irb
no ip address
duplex auto
speed auto
description WAN
ip address dhcp
ip nat outside
duplex auto
speed auto
interface wlan-ap0
ip address unnumbered Vlan4
arp timeout 0
interface Vlan1
ip nat inside
interface Vlan4
ip nat inside
interface Async1
no ip address
encapsulation slip
interface GMPLS8
no ip address
no fair-queue
no keepalive
ip http server
--> no ip nat inside source list 2 interface Wlan-GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 dhcp
logging esm config
access-list 1 permit 192.168.100.0 0.0.0.255
ip domain-lookup
no service config
control-plane
bridge 1 route ip
line con 0
exec-timeout 0 0
logging synchronous
login
line 1
modem InOut
stopbits 1
speed 115200
line 2
no exec
transport input all
line aux 0
line vty 0 4
password 7 1100105
login
transport input all
end
AP Configuration:
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 syslog
dot11 ssid Bella
dot11 ssid Bella
mbssid guest-mode
vlan 4
authentication open
guest-mode
wpa-psk ascii 0 5555555555
bridge irb
no ip address
no ip route-cache
ssid Bella
antenna gain 0
station-role root
bridge-group 1
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
description the embedded AP GigabitEthernet 0 is an internal interfaceconnecting AP with the host router
no ip address
no ip route-cache bridge-group 1
no ip address
no ip route-cache
ssid Bella
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip http server
bridge 1 route ip
no ip address
no ip route-cache
line con 0
privilege level 15
login local
line vty 0 4
login local
cns dhcp
end
I can finally ping out from the AP console , I still cannot cannot get a DHCP address when associated with the AP, I been working on this for days and i feel like im almost there
891W_Router#show config
Using 3664 out of 262136 bytes
! Last configuration change at 16:52:26 UTC Fri Sep 13 2019
version 15.5
no service pad
boot-start-marker
boot-end-marker
no logging on
no aaa new-model
ethernet lmi ce
memory-size iomem 10
rsakeypair TP-self-signed-1853469223
crypto pki certificate chain TP-self-signed-1853469223
ip dhcp pool Vlan4
dns-server 8.8.8.8
ip dhcp pool Vlan1
ip name-server 8.8.8.8
ip cef
no ipv6 cef
max-incomplete low 18000
max-incomplete high 20000
license udi pid CISCO891W-AGN-A-K9 sn FTX151604R2
redundancy
bridge irb
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
description WAN
no ip address
ip nat outside
shutdown
duplex auto
speed auto
description WAN
ip address dhcp
ip nat outside
duplex auto
speed auto
interface wlan-ap0
ip unnumbered Vlan4
arp timeout 0
no ip address
interface Vlan1
ip nat inside
interface Vlan4
ip nat inside
interface Async1
no ip address
encapsulation slip
interface GMPLS8
no ip address
no keepalive
ip http server
control-plane
bridge 1 route ip
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
exec-timeout 0 0
logging synchronous
login
line 1
modem InOut
stopbits 1
speed 115200
line 2
no exec
transport input all
line aux 0
line vty 0 4
login
transport input all
end
____________________________________
AP
version 12.4
no service pad
hostname ap
enable secret 5 $1$gUWs$SHn1YFDMXmSKX2sF.epuX1
no aaa new-model
dot11 syslog
dot11 ssid Bella
vlan 4
authentication open
guest-mode
mbssid guest-mode
username cisco privilege 15 secret 5 $1$vBe1$fdFA5dKMjuvAKH5tEeDTU/
bridge irb
no ip address
no ip route-cache
ssid 891W-WiFi
ssid Bella
antenna gain 0
mbssid
station-role root
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
ssid 891W-WiFi
ssid Bella
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip route-cache
bridge-group 4
no ip address
no ip route-cache
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
privilege level 15
login local
line vty 0 4
login local
cns dhcp
end
check if Vlan 4 is actually existing on the router (sh vlan).
Also, on the AP you have two dot11 subinterfaces for Vlan 4, not sure if that creates a problem, but to be sure, delete the second, so the config looks like this:
AP
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 syslog
dot11 ssid Bella
vlan 4
authentication open
guest-mode
mbssid guest-mode
bridge irb
no ip address
no ip route-cache
ssid 891W-WiFi
ssid Bella
antenna gain 0
mbssid
station-role root
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
ssid 891W-WiFi
ssid Bella
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip http server
bridge 1 route ip
line con 0
privilege level 15
login local
line vty 0 4
login local
cns dhcp
end
George. Thank you , It must have been the extra interface, i deleted that and it started working, thank you so much for your help
Good to hear that you got it to work finally...
i noticed GigabitEthernet0.4 and GigabitEthernet0 in your config are both in bridge group 1, could this be the problem?
#interface GigabitEthernet0
ap(config-if)#bridge-group 1
Configuration of subinterfaces and main interface
within the same bridge group is not permitted
