Cisco 9200 Mgmt VRF
uni1389
Hi All,
am using Cisco 9200 switches and assigned management IP as under mentioned. I have some other servers which are using the same IP network and with VLAN 10 , but am not able to ping switch from my laptop configured with VLAN 10 . Can you please guide me further . could i assigned VLAN 10 to mangement interface having Vrf configuration or what will be work around
 show run interface gigabitEthernet 0/0
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
ip address 10.20.10.12 255.255.255.0
end
show running-config interface gigabitEthernet 1/0/1
interface GigabitEthernet1/0/1
switchport access vlan 10
switchport mode access
spanning-tree portfast
end
With Regards
uni1389
when you ping, do you specify the vrf ?
ping vrf Mgmt-vrf 10.20.10.12
Richard Pidcock
Do you have a default route specified for your management vrf?
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 x.x.x.x name **MGMT**
Also as suggested by @Georg Pauwen , if pinging from the switch be sure to specify your management vrf
i.e. ping vrf "vrf-name" x.x.x.x
Richard W. Pidcock
Reza Sharifi
No, You can not assign the management interface (gi0/0) to a vlan. It is simply a host address that will connect to an out-of-band management switch. If you want to use vlan 10, then you don't need to use the out-of-band management port (gi0/0). Simply use gi1/0/1 with vlan 10, inband.
