CISCO 9200 "No space left on device"
abtt-39
I am trying to update a cisco 9200 switch ( in fact, it's a stack, there a 2 switchs).
Switch Ports Model SW Version SW Image Mode
* 1 32 C9200-24P 17.06.05 CAT9K_LITE_IOSXE INSTALL
2 32 C9200-24P 17.06.05 CAT9K_LITE_IOSXE INSTALL
i want to upgrade them to 17.9.3
First I did :
#install remove inactive
One the command is launched, nothing much happens, i don't retirn to the command prompt, I have to do ctrl Z
Then i copy the new image with an FTP
#copy tftp: flash:
Loading cat9k_lite_iosxe.17.09.03.SPA.bin from 10.X.X.x (via VlanX): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
%Error writing flash:/cat9k_lite_iosxe.17.09.03.SPA.bin (No space left on device)
 I rebooted the stack and redid #install remove inactive, but same result
#sh flash:
CG39-POLIGNY-CS-A3S sh flash :
-#- --length-- ---------date/time--------- path
2 2149 Aug 30 2023 11:34:31.0000000000 +00:00 boothelper.log
3 10156 Aug 30 2023 11:35:58.0000000000 +00:00 vlan.dat
4 4096 Aug 30 2023 11:39:10.0000000000 +00:00 .installer
5 5 May 03 2023 13:00:53.0000000000 +00:00 .installer/install_global_trans_lock
6 6 May 03 2023 12:05:32.0000000000 +00:00 .installer/install_issu_pid
7 14 Aug 30 2023 11:35:23.0000000000 +00:00 .installer/watchlist
8 10 May 03 2023 13:00:56.0000000000 +00:00 .installer/install_state
9 4096 May 03 2023 12:40:02.0000000000 +00:00 .installer/rollback
10 112 May 03 2023 13:01:22.0000000000 +00:00 .installer/rollback/rollback_points.txt
11 4096 May 03 2023 13:00:57.0000000000 +00:00 .installer/rollback/rb_points
12 4096 May 03 2023 13:01:22.0000000000 +00:00 .installer/rollback/rb_points/2
13 4915 May 03 2023 13:00:57.0000000000 +00:00 .installer/rollback/rb_points/2/packages.conf
14 6 May 03 2023 13:00:57.0000000000 +00:00 .installer/rollback/rb_points/2/bootdir
15 660 May 03 2023 13:01:22.0000000000 +00:00 .installer/rollback/rb_points/2/pkginfo
16 0 May 03 2023 13:01:22.0000000000 +00:00 .installer/rollback/rb_points/2/patch0.sta
17 10 May 03 2023 13:01:22.0000000000 +00:00 .installer/rollback/rb_points/2/patch.sta
18 4096 Jul 03 2022 06:43:19.0000000000 +00:00 .installer/rollback/rb_points/1
19 4920 Jul 03 2022 06:42:56.0000000000 +00:00 .installer/rollback/rb_points/1/packages.conf
20 6 Jul 03 2022 06:42:56.0000000000 +00:00 .installer/rollback/rb_points/1/bootdir
21 625 Jul 03 2022 06:43:19.0000000000 +00:00 .installer/rollback/rb_points/1/pkginfo
22 0 Jul 03 2022 06:43:19.0000000000 +00:00 .installer/rollback/rb_points/1/patch0.sta
23 10 Jul 03 2022 06:43:19.0000000000 +00:00 .installer/rollback/rb_points/1/patch.sta
24 0 May 03 2023 12:48:26.0000000000 +00:00 .installer/.install_add_pkg_list.prev.txt
25 861 May 03 2023 12:52:02.0000000000 +00:00 .installer/install_add_oper.log
26 4096 May 03 2023 13:00:56.0000000000 +00:00 .rollback_timer
27 592 Aug 30 2023 11:34:05.0000000000 +00:00 bootloader_evt_handle.log
28 4096 Jul 03 2022 06:29:45.0000000000 +00:00 core
29 4096 Jul 03 2022 06:28:07.0000000000 +00:00 core/modules
30 1 Aug 30 2023 11:51:00.0000000000 +00:00 core/.callhome
31 4096 Aug 30 2023 11:35:47.0000000000 +00:00 .prst_sync
32 233 Aug 30 2023 11:34:28.0000000000 +00:00 .prst_sync/log
33 27 Aug 30 2023 11:36:07.0000000000 +00:00 .prst_sync/reload_history
34 4096 Jul 03 2022 06:28:10.0000000000 +00:00 gs_script
35 4096 Jul 03 2022 06:28:10.0000000000 +00:00 gs_script/sss
36 5242880 Jul 03 2022 06:28:10.0000000000 +00:00 ssd
37 4096 Jul 03 2022 06:28:10.0000000000 +00:00 ss_disc
38 4096 Jul 03 2022 06:28:10.0000000000 +00:00 tech_support
39 15938 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/igmp-snooping.tcl
40 14178 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/mld-snooping.tcl
41 15828 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/multicast.tcl
42 1330 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/pkt-drop-stats-dump.tcl
43 14047 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/pkt-drop-stats.tcl
44 1365 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/platform-fabric-iid-ethernet.tcl
45 2107 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/platform-fabric-iid-ipv4.tcl
46 2109 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/platform-fabric-iid-ipv6.tcl
47 2729 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/platform-fabric-vrf-ipv4.tcl
48 2757 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/platform-fabric-vrf-ipv6.tcl
49 53606 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/platform-fabric-vrf-source.tcl
50 21811 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/platform-fabric.tcl
51 1548 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/platform_evpn_vxlan.tcl
52 26175 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/port.tcl
53 3215 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/port_dump.tcl
54 9197 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/port_utils.tcl
55 16401 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/stack.tcl
56 4937 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/stackwise-virtual.tcl
57 1496 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/tech-support-confidential.tcl
58 685 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/tech-support-dump.tcl
59 38541 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/unicast.tcl
60 336 Aug 30 2023 11:34:28.0000000000 +00:00 tech_support/utils.tcl
61 4096 Aug 30 2023 11:34:28.0000000000 +00:00 dc_profile_dir
62 295225 Aug 30 2023 11:34:28.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt
63 295225 May 09 2023 11:49:28.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt.bkp
64 4096 May 03 2023 12:23:08.0000000000 +00:00 .rommon_sync
65 866 Aug 30 2023 11:36:00.0000000000 +00:00 .rommon_sync/env_var
66 4096 Jul 03 2022 06:28:12.0000000000 +00:00 sys_report
67 4096 Jun 28 2022 03:19:54.0000000000 +00:00 .USWAP
68 4096 Aug 30 2023 11:40:34.0000000000 +00:00 .USWAP/rp
69 4096 Aug 30 2023 11:38:34.0000000000 +00:00 .USWAP/rp/sif_mgr
70 7487488 Aug 30 2023 11:38:34.0000000000 +00:00 .USWAP/rp/sif_mgr/4802.uswap
71 4096 Aug 30 2023 11:38:34.0000000000 +00:00 .USWAP/rp/stack_mgr
72 704512 Aug 30 2023 11:38:34.0000000000 +00:00 .USWAP/rp/stack_mgr/4961.uswap
73 4096 Aug 30 2023 11:38:37.0000000000 +00:00 .USWAP/rp/lman
74 303104 Aug 30 2023 11:38:37.0000000000 +00:00 .USWAP/rp/lman/7419.uswap
75 4096 Aug 30 2023 11:38:38.0000000000 +00:00 .USWAP/rp/keyman
76 241664 Aug 30 2023 11:38:38.0000000000 +00:00 .USWAP/rp/keyman/7148.uswap
77 4096 Aug 30 2023 11:38:41.0000000000 +00:00 .USWAP/rp/bt_logger
78 585728 Aug 30 2023 11:38:41.0000000000 +00:00 .USWAP/rp/bt_logger/7263.uswap
79 4096 Aug 30 2023 11:38:41.0000000000 +00:00 .USWAP/rp/btman
80 249856 Aug 30 2023 11:59:41.0000000000 +00:00 .USWAP/rp/btman/7563.uswap
81 4096 Aug 30 2023 11:38:56.0000000000 +00:00 .USWAP/rp/cmand
82 7966720 Aug 30 2023 12:00:32.0000000000 +00:00 .USWAP/rp/cmand/5414.uswap
83 4096 Aug 30 2023 11:39:24.0000000000 +00:00 .USWAP/rp/install_mgr
84 258048 Aug 30 2023 11:39:24.0000000000 +00:00 .USWAP/rp/install_mgr/11408.uswap
85 4096 Aug 30 2023 11:39:24.0000000000 +00:00 .USWAP/rp/hman
86 294912 Aug 30 2023 12:00:39.0000000000 +00:00 .USWAP/rp/hman/7676.uswap
87 4096 Aug 30 2023 11:39:26.0000000000 +00:00 .USWAP/rp/service_mgr
88 258048 Aug 30 2023 11:39:26.0000000000 +00:00 .USWAP/rp/service_mgr/18713.uswap
89 4096 Aug 30 2023 11:39:28.0000000000 +00:00 .USWAP/rp/repm
90 335872 Aug 30 2023 11:39:28.0000000000 +00:00 .USWAP/rp/repm/19560.uswap
91 4096 Aug 30 2023 11:39:29.0000000000 +00:00 .USWAP/rp/plogd
92 237568 Aug 30 2023 11:39:29.0000000000 +00:00 .USWAP/rp/plogd/20168.uswap
93 4096 Aug 30 2023 11:39:35.0000000000 +00:00 .USWAP/rp/sessmgrd
94 1523712 Aug 30 2023 11:39:35.0000000000 +00:00 .USWAP/rp/sessmgrd/17926.uswap
95 4096 Aug 30 2023 11:39:38.0000000000 +00:00 .USWAP/rp/psd
96 598016 Aug 30 2023 11:39:38.0000000000 +00:00 .USWAP/rp/psd/24872.uswap
97 4096 Aug 30 2023 11:39:42.0000000000 +00:00 .USWAP/rp/tms
98 245760 Aug 30 2023 11:39:42.0000000000 +00:00 .USWAP/rp/tms/25359.uswap
99 4096 Aug 30 2023 11:39:42.0000000000 +00:00 .USWAP/rp/fman_rp
100 970752 Aug 30 2023 12:00:19.0000000000 +00:00 .USWAP/rp/fman_rp/25709.uswap
101 4096 Aug 30 2023 11:39:42.0000000000 +00:00 .USWAP/rp/cmm
102 241664 Aug 30 2023 11:39:42.0000000000 +00:00 .USWAP/rp/cmm/26085.uswap
103 4096 Aug 30 2023 11:39:43.0000000000 +00:00 .USWAP/rp/dbm
104 1880064 Aug 30 2023 11:39:43.0000000000 +00:00 .USWAP/rp/dbm/25965.uswap
105 4096 Aug 30 2023 11:39:45.0000000000 +00:00 .USWAP/rp/linux_iosd-image
106 18006016 Aug 30 2023 12:00:39.0000000000 +00:00 .USWAP/rp/linux_iosd-image/4700.uswap
107 4096 Aug 30 2023 11:39:46.0000000000 +00:00 .USWAP/rp/cli_agent
108 1212416 Aug 30 2023 11:39:46.0000000000 +00:00 .USWAP/rp/cli_agent/26201.uswap
109 4096 Aug 30 2023 11:40:34.0000000000 +00:00 .USWAP/rp/smand
110 864256 Aug 30 2023 12:00:39.0000000000 +00:00 .USWAP/rp/smand/25146.uswap
111 4096 Aug 30 2023 11:39:27.0000000000 +00:00 .USWAP/fp
112 4096 Aug 30 2023 11:38:33.0000000000 +00:00 .USWAP/fp/btman
113 249856 Aug 30 2023 11:59:33.0000000000 +00:00 .USWAP/fp/btman/6116.uswap
114 4096 Aug 30 2023 11:38:38.0000000000 +00:00 .USWAP/fp/fed
115 9834496 Aug 30 2023 12:00:38.0000000000 +00:00 .USWAP/fp/fed/5883.uswap
116 4096 Aug 30 2023 11:39:23.0000000000 +00:00 .USWAP/fp/service_mgr
117 258048 Aug 30 2023 11:39:23.0000000000 +00:00 .USWAP/fp/service_mgr/16692.uswap
118 4096 Aug 30 2023 11:39:27.0000000000 +00:00 .USWAP/fp/fman_fp_image
119 868352 Aug 30 2023 12:00:29.0000000000 +00:00 .USWAP/fp/fman_fp_image/17654.uswap
120 4096 Aug 30 2023 11:39:24.0000000000 +00:00 .USWAP/cc
121 4096 Aug 30 2023 11:39:24.0000000000 +00:00 .USWAP/cc/iomd
122 274432 Aug 30 2023 11:39:24.0000000000 +00:00 .USWAP/cc/iomd/16694.uswap
123 4096 Jun 28 2022 03:19:44.0000000000 +00:00 .CRFT
124 134899 Aug 30 2023 11:34:31.0000000000 +00:00 memleak.tcl
125 4096 Jul 03 2022 06:28:18.0000000000 +00:00 Tbot
126 117906 Aug 30 2023 11:34:31.0000000000 +00:00 Tbot/HealthCheckDebugInfra.py
127 265373 Aug 30 2023 11:34:31.0000000000 +00:00 Tbot/L3ParseOutputs.py
128 365279 Aug 30 2023 11:34:31.0000000000 +00:00 Tbot/L3DebugInfraAPIs.py
129 155706 Aug 30 2023 11:34:31.0000000000 +00:00 Tbot/L2DebugInfraAPIs.py
130 164575 Aug 30 2023 11:34:31.0000000000 +00:00 Tbot/L2ParseOutputs.py
131 155706 Aug 30 2023 11:34:31.0000000000 +00:00 Tbot/L2DebugInfraScript.py
132 13 Jul 03 2022 06:28:19.0000000000 +00:00 NVRAM
133 4096 Jun 28 2022 03:23:57.0000000000 +00:00 .dbpersist
134 4096 Jun 28 2022 03:20:40.0000000000 +00:00 .dbpersist/history
135 4096 Aug 30 2023 11:31:42.0000000000 +00:00 .dbpersist/DMI_STATE_DB
136 15861 Aug 30 2023 11:31:42.0000000000 +00:00 .dbpersist/DMI_STATE_DB/DMI_STATE_DB
137 171 Aug 30 2023 11:35:27.0000000000 +00:00 .dbpersist/DMI_STATE_DB/DMI_STATE_DB.meta
138 6004 Aug 30 2023 11:35:27.0000000000 +00:00 .dbpersist/stats
139 15524 Aug 30 2023 11:36:00.0000000000 +00:00 rdope_out.txt
140 4096 Jul 03 2022 06:29:23.0000000000 +00:00 onep
141 4096 Jul 03 2022 06:29:23.0000000000 +00:00 onep/apps-cli
142 89 Aug 30 2023 11:35:57.0000000000 +00:00 rdope.log
143 4096 Jul 03 2022 06:29:24.0000000000 +00:00 pnp-info
144 4096 Aug 30 2023 11:35:59.0000000000 +00:00 license_evlog
145 2877 Jul 03 2022 06:32:42.0000000000 +00:00 license_evlog/SAEventRegular20220703_062945.log
146 2709 Jul 03 2022 06:47:15.0000000000 +00:00 license_evlog/SAEventRegular20220703_064629.log
147 3754 Jul 03 2022 06:52:09.0000000000 +00:00 license_evlog/SAEventRegular20220703_065023.log
148 3809 May 03 2023 11:17:27.0000000000 +00:00 license_evlog/SAEventRegular20230503_111307.log
149 3433 May 03 2023 11:25:48.0000000000 +00:00 license_evlog/SAEventRegular20230503_112547.log
150 5710 May 03 2023 11:55:01.0000000000 +00:00 license_evlog/SAEventRegular20230503_112937.log
151 7014 May 03 2023 12:22:00.0000000000 +00:00 license_evlog/SAEventRegular20230503_122109.log
152 6715 May 03 2023 12:44:10.0000000000 +00:00 license_evlog/SAEventRegular20230503_122659.log
153 4259 May 03 2023 13:18:14.0000000000 +00:00 license_evlog/SAEventRegular20230503_131743.log
154 5624 May 03 2023 13:38:16.0000000000 +00:00 license_evlog/SAEventRegular20230503_132435.log
155 6115 May 03 2023 14:25:57.0000000000 +00:00 license_evlog/SAEventRegular20230503_135216.log
156 20437 Aug 30 2023 11:31:42.0000000000 +00:00 license_evlog/SAEventRegular20230509_115154.log
157 5656 Aug 30 2023 11:39:15.0000000000 +00:00 license_evlog/SAEventRegular20230830_113558.log
158 0 Aug 30 2023 11:36:00.0000000000 +00:00 dope_hist
159 4096 Jul 03 2022 06:29:43.0000000000 +00:00 guest-share
160 2097152 Aug 30 2023 11:36:12.0000000000 +00:00 nvram_config
161 2097152 Aug 30 2023 11:36:12.0000000000 +00:00 nvram_config_bkup
162 4096 May 03 2023 11:16:51.0000000000 +00:00 pnp-tech
163 5945 May 03 2023 11:16:51.0000000000 +00:00 pnp-tech/pnp-tech-time
164 152872 May 03 2023 11:16:52.0000000000 +00:00 pnp-tech/pnp-tech-discovery-summary
165 4915 May 03 2023 12:59:45.0000000000 +00:00 packages.conf
166 10156 Aug 30 2023 11:38:17.0000000000 +00:00 stby-vlan.dat
167 427349016 Jul 03 2022 06:36:12.0000000000 +00:00 cat9k_lite-rpbase.17.03.05.SPA.pkg
168 40713581 Jul 03 2022 06:37:38.0000000000 +00:00 cat9k_lite-rpboot.17.03.05.SPA.pkg
169 4367384 Jul 03 2022 06:36:12.0000000000 +00:00 cat9k_lite-srdriver.17.03.05.SPA.pkg
170 11043860 Jul 03 2022 06:36:12.0000000000 +00:00 cat9k_lite-webui.17.03.05.SPA.pkg
171 2148 May 09 2023 11:49:30.0000000000 +00:00 boothelper.log.old
172 527146419 May 03 2023 12:44:21.0000000000 +00:00 cat9k_lite_iosxe.17.06.05.SPA.bin
173 4096 May 03 2023 13:03:33.0000000000 +00:00 fp_cc_crash
174 1261 May 03 2023 13:03:37.0000000000 +00:00 Baltimore.ca
175 464061464 May 03 2023 12:50:32.0000000000 +00:00 cat9k_lite-rpbase.17.06.05.SPA.pkg
176 44595543 May 03 2023 12:51:58.0000000000 +00:00 cat9k_lite-rpboot.17.06.05.SPA.pkg
177 5342232 May 03 2023 12:50:32.0000000000 +00:00 cat9k_lite-srdriver.17.06.05.SPA.pkg
178 13562900 May 03 2023 12:50:32.0000000000 +00:00 cat9k_lite-webui.17.06.05.SPA.pkg
179 4915 May 03 2023 12:51:58.0000000000 +00:00 cat9k_lite_iosxe.17.06.05.SPA.conf
180 1338 May 03 2023 13:03:37.0000000000 +00:00 DigiCertGlobalRootCA.ca
181 1606 May 03 2023 13:03:37.0000000000 +00:00 StarfieldServicesRootCA.ca
182 4096 May 03 2023 13:03:51.0000000000 +00:00 pd_info
183 34 May 03 2023 13:03:51.0000000000 +00:00 pd_info/system_report_trigger.log
184 15943 May 03 2023 13:03:51.0000000000 +00:00 pd_info/top_output-20230503-130351-Universal.log
185 807 May 03 2023 13:03:53.0000000000 +00:00 pd_info/smap_output-20230503-130351-Universal.log
186 4096 Aug 30 2023 12:00:21.0000000000 +00:00 .CLEANUP_IN_PROGRESS
187 48 Aug 30 2023 11:58:33.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite-rpbase.17.06.05.SPA.pkg.inuse
188 50 Aug 30 2023 11:58:33.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite-srdriver.17.06.05.SPA.pkg.inuse
189 47 Aug 30 2023 11:58:33.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite-webui.17.06.05.SPA.pkg.inuse
190 13 Aug 30 2023 11:58:33.0000000000 +00:00 .CLEANUP_IN_PROGRESS/packages.conf.inuse
191 34 Aug 30 2023 11:58:33.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite-rpboot.17.06.05.SPA.pkg.inuse
192 34 Aug 30 2023 11:59:20.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite-rpbase.17.03.05.SPA.pkg
193 34 Aug 30 2023 11:59:20.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite-rpboot.17.03.05.SPA.pkg
194 36 Aug 30 2023 11:59:21.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite-srdriver.17.03.05.SPA.pkg
195 33 Aug 30 2023 11:59:23.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite-webui.17.03.05.SPA.pkg
196 33 Aug 30 2023 12:00:21.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite_iosxe.17.06.05.SPA.bin
197 34 Aug 30 2023 12:00:21.0000000000 +00:00 .CLEANUP_IN_PROGRESS/cat9k_lite_iosxe.17.06.05.SPA.conf
245821440 bytes available (1611616256 bytes used)
Leo Laohoo
This is known bug/feature.
Reboot the entire stack and try again.
22 Replies 22
Joseph W. Doherty
Likely switch's flash cannot contain two IOS files (not uncommon).
If that's the issue, you need to erase running image.
balaji.bandi
issue command  - this will remove old IOS XE not active.
# install remove inactive
or
# request platform software package clean
then check the space and install it again.
BB
abtt-39
In fact, i had already done an #install remove inactive ( before), but nothing seemed to happen.
is this command supposed to be fast? i waited 5 minutes. And I killed the process to return to the prompt.
Then i manually deleted the old pkg files.
retry an #install remove inactive, and i waited longer. And the command was executed untill the end.
The i was able to copy my new *.bin file and install it.
i still have 2 others stacks to upgrade, i'll see what happens, i will come and post a comment here.
abtt-39
just upgraded a stack of 4 switches.
#install remove incative : It was fast, much faster than the previous stack.
The software upgrade being enable, it updated all the switches.
The installation time and reboot took around 40 minutes.
Thanks.
May the one having issue reboot in maintenance window and try again clean up and upgrade.
BB
Leo Laohoo
I had this same issue, and a reboot fixed it.
permejdal
The switch runs Linux, and when you delete a file, it is not acutally deleted while the file is open by another proccess. This means that unclosed files takes up the space required for an upgrade. This is why a reboot is sometimes required before an upgrade can be done.
I'm not a Linux expert, but generally no operating system allows you to delete a file that's currently "opened", especially by some other process/task.
What a reboot would do is eliminate whatever had the file opened, allowing the file to be deleted.
Possibly a better approach, if possible, would be to stop the process holding the file opened.
A potential issue with using a reboot, file space may still be considered allocated but unowned.  To reclaim it, you may then need to run something like 'nx's fsck.  (Possibly the OS boot will automatically free up such unowned allocated file space [or file space allocations pending in RAM until file closed - if so, with non scheduled reboot, poof, file space allocations never permanently recorded].)
Leo Laohoo
This is a well-known issue:  CSCwa71156 & CSCwo59318
conf t
 iox
end
guestshell enable
guestshell destroy
conf t
 iox
end
guestshell enable
guestshell destroy
Work arounds don't appear to include just simply rebooting will cure the described issue.
Oh, and what's described, being an issue, and how to correct, makes sense.
The above and rebooting are known workarounds.   The issue will return over time.
In the past, I would recommend "upgrade the firmware".  Nowadays, I am less and less reluctant to make that same recommendation because upgrading the IOS-XE firmware (to fix currently issues faced) will only make things worse as upgrading unleash more bugs.
Furthermore, this kind of workaround only reinforces my opinion that regular reboots (4 to 6 months for 3650/3850 &/or 12 months for Catalyst 9k switches) to keep the network "healthy" is the only direction.  So far, I have not been proven wrong.  Yet.
. . . my opinion that regular reboots . . . to keep the network "healthy" . . .
Reboots remediate memory leaks, memory fragmentation and memory corruption.
As software grows in size and complexity, and is subject to maintenance entropy, encountering more defects isn't surprising, what's surprising is that such software continues to work at all.  ; )
To explain the issue, in a network kind of way, consider a media BER spec.
If the BER spec is constant as media speed increases your error rate over time increases proportionally to the speed increase!!!
For the same BER, one corrupted bit, seen on 10 Mbps Ethernet once every 10,000 days (about 27.4 years!) and, on 100 Gbps Ethernet, is now seen once a day!
With software, its "BER" improvement hasn't kept up with its increased "speed", so it appears its quality has decreased.
Possibly AI will improve software's "BER".
BTW, as I've (very rarely) have mentioned, I'm really not a network engineer, I'm really a software engineer.
I am having a reoccurring issue of not having enough space on 9200 to do an install-mode to install-mode upgrade. So I am now doing install-mode to bundle-mode to install-mode upgrades instead. This is much more reliable. I think to underlying issue is that the images have become too large for reliable have 2 install-mode images at the same time.
Another issue I have, is that one stack member have spend about 500MB on files I cannot see with "show flash-4". I have counted the size of all the visible files to be sure. I have also rebooted and upgrade the switch to 17.12.05 using install-mode to bundle-mode to install-mode.
We can see that flash-4 have about 500MB less free space
aau-sw1#show file systems | i flash
*   1956839424     804503552      disk     rw   flash: bootflash: flash-1:
    1957167104     803733504      disk     rw   flash-2: stby-flash:
    1957167104     865599488      disk     rw   flash-3:
    1957167104     353370112      disk     rw   flash-4:
Lets see if the issue can be resolve.
aau-sw1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
aau-sw1(config)#iox
aau-sw1(config)#end
aau-sw1#guestshell enable
Interface will be selected if configured in app-hosting
Please wait for completion
The process for the command is not responding or is otherwise unavailable
aau-sw1#guestshell destroy
% Error: The application: guestshell, does not exist
aau-sw1#guestshell disable
aau-sw1(config)#no iox
aau-sw1(config)#end
*   1956839424     803766272      disk     rw   flash: bootflash: flash-1:
Nope, did not work.
