Cisco 9200 Stackwise Modules Hot Swappable
Kazuhira
Community Member
I currently have a Cisco 9200 switch that does not have a stackwise module at the back. This switch is currently powered on and I am wondering if I can just leave it running and install a stackwise module?
Once I added the stackwise module at the back.. can I also once again leave it running and add a new switch to the stack?
Thanks!
9 Replies 9
balaji.bandi
as per i know its not hot swapable, i suggest to take maintenance window (Power off the switch and install is the safe approach).
BB
timothy-fletcher
Community Member
I'm sure by now you've already got this all figured out, but for the next person like myself, yes, stacking modules are in fact hot-swappable.
Johan.vanbaarlen
Frequent Visitor
Frequent Visitor
Can anyone confirm that the modules are indeed hot-insertable? I've got to add stacking to a currently-single 9200L, and it would be so much easier if it could indeed be done without having to shutdown the switch and thus the entire department behind it.
  - @Johan.vanbaarlen                        They are not hot-insertable ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hello @Johan.vanbaarlen ,
the stacking modules have to be inserted electrically in the switch backplane switching matrix.
So as already suggested by @Mark Elsen it is highly recommended to power off the switch and then insert the modules
Plan for a maintenance window to make the changes.
Hope to help
Giuseppe
jameh0266
Community Member
Here’s a clean reply you can post in that thread:
Short answer: technically yes, but don’t rely on it in production without a maintenance window.
For Catalyst 9200, the StackWise modules themselves are generally considered hot-swappable hardware, meaning you can physically insert/remove them while the switch is powered on without damaging anything. (Holcon Systems LTD)
However, Cisco doesn’t clearly position stack modules the same way as things like power supplies or uplink modules (which are explicitly documented as hot-swappable), so behavior can vary depending on software and timing. (Cisco)
In practice:
  • You can usually insert the stack module with the switch running
  • But forming or modifying the stack (adding switches, cables, etc.) can still trigger stack election, reloads, or instability
  • Even if it “works live,” you don’t want to risk unexpected disruption on a production switch
That’s why most people (and TAC guidance) still recommend doing this during a maintenance window.
So the safe approach is: power down, install the module, then bring it back up.
The “it works hot” approach is possible, but not something I’d trust unless downtime doesn’t matter.
 - @Johan.vanbaarlen  - Follow up , concerning the opinion  of @jameh0266  : if proceeding without power down , issue the command : terminal  monitor ; first.
  This to get console messages duplicated on your current SSH connection too
 M
Unfortunately that's no new information 😞 One supplier says 'yes you can', but Cisco says 'no you can't'. Of course it is safer to do a cold install. But this is one of those cases with conflicting interests, one says 'I need it done' and the other 'but you can't shutdown to do it'. But I guess somebody will be disappointed - full downtime it will be.
 - @Johan.vanbaarlen   I think that' safer : I have the habbit width such type of questions , to both query ChatGPT and Copilot ; both said NO. Arguments are a bit fuzzy
 M.
